  • SNR≥126dB; THD+N<0.00008%
Swappable Op-Amp Design
Bypass Mode
Trigger In/Out
Perfect Match to ZA3 Amp
  • Maximum Sampling Rate:
    USB: PCM 32bit/768kHz; DSD512
    OPT/COAX: PCM 24bit/192kHz
    Bluetooth: PCM 24bit/48kHz
  • Output Level:
    XLR: 5Vrms RCA: 2.5Vrms
  • Output Mode: XLR, RCA
  • SINAD: 126dB
  • THD: ≥120dB
  • THD+N: <0.00008%
  • Dynamic Range: ≥123dB
  • Noise Floor: ≤2μV
  • Bluetooth Version: 5.0
  • Power Supply: DC 12V 1.5A
  • DAC ZD3 *1
  • 12V Power Adapter *1
  • Infrared Remote Control *1
  • USB-A to USB-B Cable *1
  • 3.5mm Trigger Cable *1
  • USER MANUAL *1
From $179.99
DAC Preamp
XLR, RCA
<0.00008%
≥126dB
Chipset
DC 12V/1.5A
From $119.99
DAC+Headphone Amp
250mw@32Ω
RCA, 3.5mm Headphone Jack
>103dB
Chipset
16-300Ω
DC 12V/1.5A
From $199.99
DAC+Headphone Amp
2x 2.1W@32Ω
≤ 0.0002%
≥121dB
Chipset
16-300Ω
DC 12V/2A
From $99.99
DAC+Headphone Amp
1.1W@32Ω
USB-C, Optical
≤0.001%
≥120dB
Chipset
16-300Ω
How to replace the op-amps?
Based on 156 reviews
82%
(128)
12%
(19)
3%
(5)
Ian
Excellent DAC with my Krell and Electrocompaniet amps.
Excellent product for us!! We stream music from a Xiaomi tv box Gen2 most of the time (YouTube and Tidal). This ZD3 DAC works excellent connected with XLRs to either of my amps (Krell KAV 300i or Electrocompaniet ECI 3). Man, this DAC sounds fantastic!! Thanks for a great product! Looking forward to play around with the Op-Amps.
César
Buena calidad- precio
Llego en buenas condiciones y rápido. No se pagan impuestos ni cuotas adicionales a Mexico. Buena relación calidad precio. Lo conecte a un receptor Onkyo tx rz30 con buenos resultados.El botón de funciones puede mejorar se sentía un poco flojo.
Francisco Gallego Aguayo
Sonido muy limpio y potente.
Me encanta, es pequeño pero suena genial.
J.G.
Really enjoying my ZD3 and ZA3 combo.
I purchased the ZA3, ZD3, and Box X5 for a new stereo build that is going in our living room along with two POLK ES20 bookshelf speakers and a Fluance rt82 turntable. I connected the ZA3 and ZD3 with XLR and attached and ran an HDMI ARC from our TV to the unit. Everything else is RCA/speaker wires... What's awesome is that when running audio through the TV, everything can be handled by the TV remote! This makes for an easy streaming system. It even handles power on and off... I wasn't sure what to expect with the HDMI ARC, but it has been the most used feature of the ZD3.
All in all, for a small bookshelf system, I really think Fosi has done a great job here. I've been watching the company grow for the last ~5 years and really happy with their gear so far. Only nit pick... The power supplies feel a bit lacking in quality. I'm sure they're fine, but the cords feel very thin and flimsy.
Jakub Jakubowski
JJ Fosi Audio ZD3
Sound quality is quite good for the price but I have some strange issues regarding volume controls and connectivity. Sometimes volume “sticks” and don’t change when knob is turned. Sometimes when the device is turned on by HDMI Arc input it makes loud static noise for couple seconds.
