  • SNR≥126dB; THD+N<0.00008%
Swappable Op-Amp Design
Bypass Mode
Trigger In/Out
Perfect Match to ZA3 Amp
  • Maximum Sampling Rate:
    USB: PCM 32bit/768kHz; DSD512
    OPT/COAX: PCM 24bit/192kHz
    Bluetooth: PCM 24bit/48kHz
  • Output Level:
    XLR: 5Vrms RCA: 2.5Vrms
  • Output Mode: XLR, RCA
  • SINAD: 126dB
  • THD: ≥120dB
  • THD+N: <0.00008%
  • Dynamic Range: ≥123dB
  • Noise Floor: ≤2μV
  • Bluetooth Version: 5.0
  • Power Supply: DC 12V 1.5A
  • DAC ZD3 *1
  • 12V Power Adapter *1
  • Infrared Remote Control *1
  • USB-A to USB-B Cable *1
  • 3.5mm Trigger Cable *1
  • USER MANUAL *1
From $179.99
DAC Preamp
XLR, RCA
<0.00008%
≥126dB
Chipset
DC 12V/1.5A
From $119.99
DAC+Headphone Amp
250mw@32Ω
RCA, 3.5mm Headphone Jack
>103dB
Chipset
16-300Ω
DC 12V/1.5A
From $199.99
DAC+Headphone Amp
2x 2.1W@32Ω
≤ 0.0002%
≥121dB
Chipset
16-300Ω
DC 12V/2A
From $99.99
DAC+Headphone Amp
1.1W@32Ω
USB-C, Optical
≤0.001%
≥120dB
Chipset
16-300Ω
How to replace the op-amps?
Based on 168 reviews
81%
(136)
13%
(22)
4%
(6)
Miha
Good DAC
All I miss is I could sqitch it off by pressing the orange button once, but you have to hold it ... Guess some people use remotes ...
Reidar
Perfect DAC match for my Genelec speakers
Very good design and functions perfect for my sources. Easy to use and easy to pair.
v
vlad335
I am completely surprised!
Just got the ZD3 for a secondary system. Arrived today and I put it in my PC setup which uses a Denafrips Ares II as the DAC. Granted, the ZD3 isnt as good as the Ares, but it was surprisingly close! We are talking about a DAC that is nearly 10 times the price!
I ordered a pair of Sparkos ss3602 opamps and will try it in this setup again using the same test track.
DAVID DELVALLE
Satisfaction guaranteed
Well... delivery time was on point. It arrived at the stipulated time. The product is excellent and surpassed my expectations. It is a privilege to be able to hear and this product has enhanced the experience and I recommend it to everyone. Thank you for the service rendered.
Jeffrey Hill
I love this unit
Inserting the ZD3 between my tv and my powered monitor speakers took every aspect of convenience and sound quality to levels that I did not expect out of such an affordable unit. I may upgrade the opamp at some point, but I am in no hurry. It sounds absolutely superb as is.Fit and finish is just as immaculate as the sound quality.
