  • SNR≥126dB; THD+N<0.00008%
Swappable Op-Amp Design
Bypass Mode
Trigger In/Out
Perfect Match to ZA3 Amp
  • Maximum Sampling Rate:
    USB: PCM 32bit/768kHz; DSD512
    OPT/COAX: PCM 24bit/192kHz
    Bluetooth: PCM 24bit/48kHz
  • Output Level:
    XLR: 5Vrms RCA: 2.5Vrms
  • Output Mode: XLR, RCA
  • SINAD: 126dB
  • THD: ≥120dB
  • THD+N: <0.00008%
  • Dynamic Range: ≥123dB
  • Noise Floor: ≤2μV
  • Bluetooth Version: 5.0
  • Power Supply: DC 12V 1.5A
  • DAC ZD3 *1
  • 12V Power Adapter *1
  • Infrared Remote Control *1
  • USB-A to USB-B Cable *1
  • 3.5mm Trigger Cable *1
  • USER MANUAL *1
From $179.99
DAC Preamp
XLR, RCA
<0.00008%
≥126dB
Chipset
DC 12V/1.5A
From $119.99
DAC+Headphone Amp
250mw@32Ω
RCA, 3.5mm Headphone Jack
>103dB
Chipset
16-300Ω
DC 12V/1.5A
From $189.99
DAC+Headphone Amp
2x 2.1W@32Ω
≤ 0.0002%
≥121dB
Chipset
16-300Ω
DC 12V/2A
From $99.99
DAC+Headphone Amp
1.1W@32Ω
USB-C, Optical
≤0.001%
≥120dB
Chipset
16-300Ω
How to replace the op-amps?
Based on 165 reviews
81%
(134)
13%
(21)
4%
(6)
DAVID DELVALLE
Satisfaction guaranteed
Well... delivery time was on point. It arrived at the stipulated time. The product is excellent and surpassed my expectations. It is a privilege to be able to hear and this product has enhanced the experience and I recommend it to everyone. Thank you for the service rendered.
Jeffrey Hill
I love this unit
Inserting the ZD3 between my tv and my powered monitor speakers took every aspect of convenience and sound quality to levels that I did not expect out of such an affordable unit. I may upgrade the opamp at some point, but I am in no hurry. It sounds absolutely superb as is.Fit and finish is just as immaculate as the sound quality.
Jeff M
Only three star rating because of the XLR cables. The DAC is a good buy
At the time I was making a purchase of the ZD3 DAC I asked a question about the balanced XLR cables that FOSI Audio had for sale I wanted to know if this was one cable for the price or if it was a pair of cables so I clicked the need help button on the web site and asked the question is this a single cable or is it a pair of cables? The answer I got was it is a single cable. I asked a second time because it showed two cables in the web page picture and the web page help said is was only one cable so I made an order of two for the cables and it ended up that I got two pair of cables I didn’t like that so I will give only a three star rating. On the other hand I do like the DAC it is a good buy.
Lance Johnston
Zd3 vs jbl
I've been connecting to my older JBL home theater with my phone and thinking it sounded good enough. I upgraded my speakers and wanted newer tech to drive them. I compared the sound quality between the onboard DAC installed in the JBL and the Fosi ZD3. The fosi was a big improvement. I could hear the actual cymbal strikes, not just crashes distorting into the next crash. Deeper base too.
Scott W
Gave new life to my 40 year old Polk speakers
After my original amp imploded I had let the speakers sit, but finally pulled the trigger on the ZD3 and 2 ZA3s. Back to listening and enjoying my music collection.
