  • Perfectly suited for your desktop or a smaller space in your home or office, the digital amplifier is easy to connect to your audio system with no software to install or settings to change;
  • 100W X 2(4 ohms, 20 Hz - 20 kHz, 0.04% THD), comes with 24V power supply, can drive 280watts(8 ohm), 320watts(4 ohm) speakers;
  • Simple compact design but practical and powerful; No pop, no audible noise, dead silent when nothing is playing through it;
  • Home small hi-fi integrated amplifier, Sturdy, Lightweight, Aluminum enclosed amp makes it perfect for projects and DIY.
Extraordinary Clarity Hi-Fi Sound
Enjoy Hi-Fi music with a next-generation stereo amp for unrivaled sound quality. Improved channel balance, lower noise floor, and overall   A purer sound. Reduced distortion and increased dynamic range. Clean and potent power output.
Advanced Audio Architecture
The High-Performance Texas Instruments TPA3116D2 Chip presents music with rousing highs and deep lows. Even at high volumes, there’s less than 0.04% harmonic distortion resulting in remarkable clarity.
Irresistible Finish
Fosi Audio TB10A amplifier curved edges and sleek controls accentuate its unibody design. With truly useful features, and thoughtfully designed premium enclosures. A new generation: exquisite design, improved operation.
Drive passive speakers
Perfect if you prefer separate passive speakers and preamps for your audio setup. 100 watt per channel power output can drive most home passive speakers to create astonishing Sound.   Easy to fit your audio system with RCA input
Upgraded DC Outlet
The old version amp or other brand amplifiers sparks flying when the power supply plugin, it's unsafe. With a built-in power protection circuit, there are no sparks flying when you plug the power adapter into the amplifier. Safe for use!
24V/4.5A Power Supply
Unlike other amplifiers come with a cheap 12V power supply. Fosi Audio TB10A equip with an energy-efficient and stable power supply which got authoritative certification by many security tests that can get an astonishing sound.
  • 1. Power supply voltage range: 15v-24v;
  • 2. Power supply range: 90w - 120w;
  • 3. THD: ≤ 0.5%;
  • 4. Frequency Range: 20Hz - 20kHz (±1 dB);
  • 5. SNR: ≥ 98dB;
  • 6. Input sensitivity: ≤ 280mV;
  • 7. Terminating impedance: 2Ohm - 8Ohm;
  • 8. Output power: 100W + 100W;
  • 9. Input mode: Analog;
  • 10. Supplied Accessories: Amplifier, Power Supply, AC Cable, Manual.
  • 5 stars: 2 (100%)
  • 4 stars: 0 (0%)
William A.
Better than we need, but Glad we got it.
We didn't really need such a hi-fi amp, but the price and size and ability to drive low-Z loads made it an easy decision. Very happy with it.
Sahil
Quality
Best Amp sond
