  • Versatile DAC Amp: The K7 is designed for both HiFi headphone audiophiles and music lovers. It can serve as a powerful hub for building your desktop audio system. Whether your're enjoying music, gaming or working, the K7 handles it all with ease.
  • Audiophile-Grade Chipset: Equipped with the AK4493S DAC, XMOS XU208 USB processor, and TPA6120 headphone amps, the K7 supports high-resolution decoding up to PCM 384kHz/32bit and DSD256. With up to 2100mW output power, it easily drives demanding headphones.
  • Comprehensive Connectivity: Supports USB-C, coaxial, optical, Bluetooth aptX HD/LL and 3.5mm microphone input. Outputs include 4.4mm balanced, 3.5mm single-ended, and RCA—easily connecting to headphones, powered speakers, or amplifiers for desktop setups.
  • User-Centric Design: Compact yet user-friendly, the K7 features dual large control knobs, five shortcut buttons, and an angled chassis for ergonomic comfort. A high-resolution display shows real-time status, making operation easy and intuitive.
  • Durable All-Metal Build: Crafted from solid aluminum alloy, the K7 features a rugged, wear-resistant chassis with a sleek metallic finish and enhanced electromagnetic interference shielding.
