Hi-Fi Amp with Clean Sound Quality: Fosi Audio M03 subwoofer amp adopts the Instruments TPA3255D2 chip, High Efficient Power Output Up to 200Watt, providing 150 watts RMS into 4-ohm loads or 120watts to 8-ohm loads. Great amplifier to driver any bookshelf speaker or subwoofer;
Subwoofer amplifier and Full-Frequency Mono Amp: Switch to PBTL, it's a Full-Frequency Mono amp for driving passive speakers and powered subwoofer. Switch to SUB, it's a subwoofer amplifier for diving passive and powered subwoofers;
Mini Compact but Powerful: Built-in low pass filter for 20-300Hz subwoofers with SUB frequency control, small simple compact design but practical and powerful;
Home Hi-Fi amplifier: Exclusively designed for the customers who pursue HiFi sound; MAX Power Output:200Watt. Note: The package comes with a 32V/5A power supply, you need a more powerful power supply to get the MAX power output;
![Subwoofer Amplifier 200 Watt Mini Mono Audio Amp Full-Frequency and Sub Bass Switchable Amplifier One Channel Home Theater Single Power Subwoofer Amp Fosi Audio M03](https://cdn.shopifycdn.net/s/files/1/2251/7913/files/a__01_a792a356-d711-4760-9c8f-799cd958f067.jpg?v=1637575230)
![Subwoofer Amplifier 200 Watt Mini Mono Audio Amp Full-Frequency and Sub Bass Switchable Amplifier One Channel Home Theater Single Power Subwoofer Amp Fosi Audio M03](https://cdn.shopifycdn.net/s/files/1/2251/7913/files/a__06_31aca69d-90bf-46ba-9285-26e1eb12ee42.jpg?v=1637575245)
Specifications | Details |
Model | M03 |
RMS Power Output: | RMS 200watt at 4ohm, RMS 100watt at 8ohm |
Terminating Impedance | 4-8Ω |
Input Sensitivity | ≤ 0.2mV |
Full Frequency Response Range | 20Hz-20KHz(± 3db) |
Bass Frequency Range | 20-200Hz |
THD | ≤0.03% |
SNR | ≥ 106dB |
DC Input Range | 24-35V |
Power Supply | 32V 5A |
Item | Quantity |
Fosi Audio M03 Amplifier | x 1 |
32V 5A Power Adaptor | x 1 |
User’s Manual | x 1 |
