Load video:
  • SNR≥ 110dB; THD+N≤ 0.003%
P4 & ZP3 Comparison
Channel: 2.0
Input Mode: RCA*3
Output Mode: RCA, Pre-out
SNR: ≥ 110dB
Dynamic Range: ≥ 110dB
THD+N: ≤ 0.003%
Crosstalk: ≥ 105dB
Noise Floor: ≤ 9μV
Tone Adjustment Gain: ±12dB
Power Supply: DC 12V/1.5A
  • 12V/1.5A Power Supply x 1
  • User’s Manual x 1
From $199.99
Fosi Audio ZP3 Preamplifier
Preamp
RCA x2, XLR
RCA, XLR, Sub-Out
Bass & Treble Control
≤ 0.0007%
≥ 115 dB
From $99.99
Preamp
RCA x3
RCA, Pre-Out
≤ 0.003%
Preamp+Headphone Amp
≤0.02%
≥103dB
Based on 149 reviews
89%
(133)
8%
(12)
William Seaver
Rate replacement for Bose
When your Bose lifestyle system
dies this is a great replacement for the controller.
Amit
The issues for *me* are:
1. the Pre Out is like post fader on a mixing desk, meaning effects are applied, meaning if you play with the eq, you change the signal going out of the Pre Out.
Problem is that if you use the Pre Out to drive a sub (which probably 98% of users do?) and Main Out to drive speakers, and you want to eq the speakers... well you also eq the sub, change it sound and volume so all your balance goes off :-\
2. I feel the remote granularity of controlling the volume is too crude. many times I feel like one tick up is too loud and one tick down is too quiet, which means I need to walk to the preamp and manually set the volume.
If those issues can be fixed with mod instructions from Fosi (I know how to use a soldering iron) then this preamp could get 5 stars.
If one issue can be solved? 4 stars.
As is, for me? that's 3 stars.
Other then that, build is solid, knobs feel good, finish perfect, no noise what so ever, eq is very nice. I actually wanted to buy another one for a second system, but obviously I won't.
WOONG KYU JEONG
깔끔하고 편해서 좋습니다.
여러 입력소스를 셀렉터 변경으로 사용중
P4로 구입후 변경하였는 데
리모컨 사용도 할 수 있어 정말 편하고 안정적입니다.
Sharonda Miller
Product delivered as ordered. Everything is fine.
Odell Hudson
Compact device, but well-built and possesses all the necessary functions.
