  • Gold Plated Banana Plugs: An exclusive accessory for Fosi Audio home audio systems, featuring excellent conductivity to reduce signal loss, enabling audio products to seamlessly integrate with your bookshelf speakers
  • Precise Manufacturing Quality: The speaker banana plug is made from aviation-grade aluminum alloy and manufactured through precise CNC machining, ensuring a long service life
  • Easy to Use: Make it easy to install speaker wires, which are very suitable for use with receivers, amplifiers, surround sound systems, banana wall panels, etc.
  • What You Get: Fosi Audio Banana Plugs, 2 Pairs/ 4 pcs
  • 5 stars: 49 (88%)
  • 4 stars: 6 (11%)
  • 3 stars: 1 (2%)
I like the look, but also how they work
It’s kinda silly to write a review on something as simple as some banana plugs, but that said, if like me, you are a Fosi HiFi household, then keeping everything in the family is a must.
I like the branding and how they look, but also how they feel and function. Can you find other banana plugs that are worst or better, bigger or smaller? Yes, but for me these just look god and work as intended.
Not sure what better review than that you can give a product, they just work!
Guillermo (United States)
It��s kinda silly to write a review on something as simple as some banana plugs, but that said, if like me, you are a Fosi HiFi household, then keeping everything in the family is a must.
Zlatri (Sweden)
Banankontakt!
I used my points to get these for almost free, super fast shipping and works as intended, gives my cables a more luxurious look.
Zlatri (Sweden)
Banankontakt!
Egr (Moldova)
Great plugs
Great plugs, satisfied
Egr (Moldova)
Great plugs
George (Qatar)
Amazing product
Its really amazing product superb
George (Qatar)
Amazing product
George (Qatar)
Amazing product
Greetings from Qatar, its superb product
George (Qatar)
Amazing product
George (Qatar)
Amazing product
Greetings from Qatar, fosi its amazing product love it
George (Qatar)
Amazing product
Cesar (Mexico)
Buen Material y Prácticos
Conectores de buen material, ligeros y prácticos.
Cesar (Mexico)
Buen Material y Pr��cticos
Conectores de buen material, ligeros y pr��cticos.
WOONG (South Korea)
Good ~~
고급지고 좋습니다.
WOONG (South Korea)
Good ~~
Martin (The Netherlands)
Ik like the way they have to be assembled...
BRAYAN (Colombia)
BRAYAN (Colombia)
Anonymous (Bulgaria)
The items arrived on time and worked as expected.
Francois (United States)
Nice speaker cables
Very nice and sleek cable for the price. I recommend.
Nice speaker cables
Anonymous (Germany)
Awesome
Miguel (United States)
Easy install
These make installing and removing speaker wire so much easier
Easy install
Alvaro (United States)
Fosi Audio Speaker Banana Plugs
this is a great buy, the are quality material and look very expensive. will be buying more for my hi fi system.
