Fosi Audio Vacuum Tubes 7-Pin
Each package contains a pair of fully tested and matched vacuum tubes (2 PCS).
5654W vacuum tubes for T20, P1, P2, Box X2, Box X4. Substitute for 7-pin 6AK5/6AK5W/6Zh1P/6J1/6J1P tubes. It can also directly replace WE-403A/403B/EF95 and ordinary 5654.
- 6J1, 6CB6A, 6Ж3N, 6J5, 6Ж5N tubes are compatible with audio devices such as BOX X2, BOX X4, P3, GR40, MC331, and T20X MKII.
Note: Replacing the wrong type of tube may damage your amplifier. If you are not sure this 5645W can be used as a replacement for your audio device, please check with your amplifier manufacturer.
It has a fuller, wider sound stage. The treble is smoother and the bass is a little bit tighter. And you can hear some details that you did not hear before while listening to more complex music.
Every package you get goes through our careful packaging. With 18 months warranty. If you have any questions, please feel free to contact us.
- All vacuum tubes have been fully tested and strictly matched.
- These vacuum tubes are compatible with audio equipment including BOX X2, BOX X4, P3, GR40, MC331, T20X MKII, etc.
- Using an incorrect vacuum tube model may damage your amplifier. If you are unsure whether these tubes are suitable for your audio device, please confirm with the amplifier manufacturer.
