Load video:
Built on User Voices
  • Input: RCA x2 and XLR
  • Output: RCA, XLR, SUB
Channel: 2.0
Input: RCA x2, XLR
Frequency Response
XLR/RCA:
20Hz-20kHz (±0.2dB)
80Hz-20kHz (±0.2dB)
120Hz-20kHz (±0.2dB)
SUB: 20Hz-200Hz (±0.2dB)
Balanced Output (XLR)
SNR: ≥ 112 dB
Dynamic Range: ≥ 112 dB
THD+N: ≤ 0.0007%
Noise Floor: ≤ 6μV
Single-Ended Output (RCA)
SNR: ≥ 115 dB
Dynamic Range: ≥ 115 dB
THD+N: ≤ 0.0008%
Noise Floor: ≤ 4μV
  • Fosi Audio ZP3 x 1
  • IR Remote Control x 1
  • AC 110-240V Power Cord x 1
  • 12V Trigger Cable x 1
  • User Manual x 1
From $199.99
Fosi Audio ZP3 Preamplifier
Preamp
RCA x2, XLR
RCA, XLR, Sub-Out
Bass & Treble Control
≤ 0.0007%
≥ 115 dB
From $99.99
Preamp
RCA x3
RCA, Pre-Out
≤ 0.003%
Preamp+Headphone Amp
≤0.02%
≥103dB
Based on 33 reviews
76%
(25)
24%
(8)
Cesar
ES mi primer equipo separado. Lo tengo acoplado a dos amplificadores V3 mono y un DAC ZD3. Me gusta el rendimiento, lo tengo conectados por XLR. Lo único que podría pedirse es algún indicador lumínico de volumen. El control puede controlar otros equipos de la marca.
Bill Skelton
Lots of options!
This is my first discrete pre-amp and there's a lot to take in here. I particularly like being able to use the balanced XLR cable option to connect my pair of ZA3 amps in mono mode and continuing the balanced set up to connect the preamp to my Eversolo DMP-A6 streamer. Still working through all the various options and really enjoying the Fosi gear, not to mention the absolutely outstanding customer service. Super fast responses to my questions. Couldn't be better!
Kurt Collins
Nice but...
I bought because of the XLR into Mono Block amps, that works well. I also wanted to have the trigger feature, works but slowly. My main issue is turning it on and off, I don’t use the remote because I already have 6 on the stand. Turning on and off the ZP3 is a hassle, Fosi Make the on=off the volume button, a push in.
Marquitta Schinner
Darrin Towne
