Fosi Audio ZH1 Smart-Tuned Fully Balanced Desktop DAC Amp
- AI Smart PEQ Tuning
- 2300mW Fully Balanced Power
- HiFi Versatility
- Dynamic Display & RGB Control
Generate personalized PEQ settings with one tap using AI presets, Harman Target matching, and web-based visual EQ control. - 2300mW Fully Balanced Power
ES9039Q2M DAC, XMOS XU316, and dual-power balanced architecture deliver up to 2300mW @ 32Ω with ultra-low 1.9μV noise. - HiFi & Gaming Versatility
6.35mm and 4.4mm outputs, 3-level gain, and UAC 1.0 support make it compatible with IEMs, headphones, PCs, CD transports, PS5, and Nintendo Switch. - Dynamic Display & RGB Control
1.2" HD LCD, aluminum knob, touch controls, and 9 customizable RGB lighting modes provide intuitive control and visual feedback.
Compare PowerCore Series
Product Specification
DACESS ES9039Q2M
USB ProcessorXMOS XU316
AmplifierTI TPA6120 x2
Amplifier CircuitFully Balanced Class AB
Balanced Output Power (32Ω/THD+N<1%)2300mW x2
Single-Ended Output Power(32Ω/THD+N<1%)589mW×2
InputsCoaxial, Optical, USB
Outputs3.5mm, 4.4mm, 6.35mm, RCA
Remote Control——
Headphone Impedance8-300Ω
MAX Sampling RatePCM 32bit/768kHz, DSD512
SNR≥ 124dB
Dynamic Range≥ 124dB
THD+N≤ 0.0002%
Noise Floor≤1.7μV
Power InputDC 12V-15V
