NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
  • Channel : 1.0
  • Input : RCA, XLR, ¼" TRS
  • SNR : ≥123dB
  • Dynamic Range : ≥123dB
  • THD : <0.006%
  • Terminal Impedance : 2-8Ω
  • Standard PSU : 48V/5A
From $109.99
300W@4Ω
RCA, XLR, ¼”TRS
Speaker Output
<0.006%
≥123dB
From $109.99
2.0 CH Amp
RCA, XLR, ¼”TRS
Speaker Output, Sub-Out
<0.006%
≥106dB
From $69.99
2.0 CH Amp
Passive Speakers, Pre-Out
≥ 108dB
From $89.99
Subwoofer Amp/MoxAmp
200W
≤0.03%
≥ 106dB
4-8Ω
32V/5A
Based on 129 reviews
83%
(107)
14%
(18)
3%
t
threej
Superb Class D
I have two pairs of V3 Monobolocks. One powers A/D/S/ M15 tower speakers, using two 48v 10A power supplies and two Fosi filters.
Another, using a single 48V 10A power supply and filter, feeds exceptional bookshelf speakers* I built.
The first monoblocks obtain their signal from a ZP3 preamp and ZD3 DAC (optical out from a Squeezebox Duet) or an X5 Phono preamp (Denon DP72L turntable with a Shure M97xE cartridge).
The second are fed by a P4 preamp and Q6 DAC (optical out from an Apple Airport Express).
Both setups have considerably surprised me, especially since the first replaced a venerable, renowned set of Tandberg 3002A pre- and 3006A power amps.
I have placed a pair of 120mm pancake fans under each pair of monoblocks and set their speed to medium, which is near silent and effectively cools the amps.
It delights me that wonderful sound can be had from my assortment of Fosi equipment.
*(6.5" Tonegen woofers, 1" fabric dome Tonegen tweeters in a ¾" MDF acoustic suspension enclosure containing high-quality crossover components, cabinets covered in oiled walnut veneer --constructed according to a late 1990s design in two Audio Magazine articles by Ken Kantor, speaker designer at Acoustic Research and founder/speaker designer of NHT).
Juan Camilo Hernandez Figueroa
Good but hot
They sound pretty good but is really hot, would like to see a V4 mono more heavy, big and better heat disipation.
Martin Bonadio
Impressed
Really impressed with the performance of my v3 mono blocks. Moved from a large underpowered integrated amp to Fosi class D mini components and wasn’t sure what to think. But these two little amps really drive my hard to power speakers!
Jean-Philippe
Sounds good to me
Excellent built. Great feature and sound really good on my DIY Toid Epics. With the 10 amps power supplies for each, it's perfect. Great product. Thank you Fosi's team.
c
charles booth
replaced dead channel on M33
worked very well. Great built quality, sound.
