BT20A Pro
New Generation 2-Channel Bluetooth Power Amplifier
BT20A Pro
OVERVIEW
FEATURES
SPECS
Product Descriptionโ€‹
The Fosi Audio BT20A Pro is a new generation Bluetooth amplifier integrating the high-performance Texas Instruments 3255 amp chip, which can bring up to 300W power per channel and allows ultra-low distortion across the audio band and superior audio quality. With tone controls, you can adjust the treble and bass in catering to your own preference. The BT20A Pro is designed and made to bring you a whole new music enjoyment experience.
Reviews are in...
Fosi Audio offer an excellent amplifier for a very low price. The package is good, it has good driving power, and BT20A PRO is a nice overall deal for sure.
Given its sound quality and feature set, the Fosi BT20A Pro provides an excellent starting place for a beginning audiophileโ€™s journey or as a replacement for an old, low-power receiver.
This tiny integrated amp packs solid power and performance for its size, and unlike most mini amps, it looks nice enough to use in a living room.
Equipped with the popular TI TPA3255 chip, it offers excellent value for money with very good build quality.
Experience Music in an Entirely New Wayโ€‹
A great budget HiFi gear to accompany your turntable, CD player, and speakers.โ€‹
Bluetooth 5.0 Connectionโ€‹
Connect your mobile phone, tablet, or other Bluetooth devices easily and quickly.โ€‹
Listen, Feel and Wonderโ€‹Logarithmic Taper A Potโ€‹
Personalized control knobs give a nice gradual increase or decrease, providing smooth gain and tame progression. Tone controls with midpoint potentiometers allow for pure original tone output.โ€‹
High-End Amp Chip Integratedโ€‹
The TPA3255 chip, compatible with 24V~48V power supply, enables true premium sound quality and low power stage idle losses with class-D efficiency.โ€‹
Replaceable Op-Ampsโ€‹
Replaceable Op-Amp Chip Choose your favorite op chips to replace the socketed NE5532 to have your preferred sound signature.
Advanced Inductorsโ€‹
High quality inductors ensure large and stable power output for the best listening experience.โ€‹
Superior Audio Performanceโ€‹
The BT20A Pro amplifier provides you with high performance sound without issues. It delivers a clean, accurate sound when you are playing either classical or modern pop music.
Product Detailsโ€‹
Max Power Output: 300Wx2 @4ฮฉ
SNR: โ‰ฅ108dB
Terminating Impedance: 2-8ฮฉ
THD: 0.005%
Power Amplifier Chip: TPA3255
Power Supply: 32V 5A
Input Range: DC 24V-48V
Frequency Response Range:
20Hz-20kHz(ยฑ1.2dB)
Bluetooth Transmission Range: Up to 50Ft
Bluetooth Codec: AAC/SBC
Input & Output
Audio Input: RCA/Bluetooth
Audio Output: Speaker Output/3.5mm Pre-out
Download
User Manual:                 Download
What's in the box๏ผŸ
1. BT20A Pro ร— 1
2. User Manual ร— 1
3. Bluetooth Antenna ร— 1
4. 32V/5A Power Supply ร— 1
