Fosi Audio DA2120C Bluetooth 2.1 Channel Amplifier Subwoofer DAC with Remote Control for Speakers With 32V 5A Power Supply
home Amplifier
 Bluetooth Amplifier Subwoofer DAC
Fosi Audio bluetooth amp
home Amplifier
home Amplifier
$149.99 USD
$149.99 USD
$159.99 USD
multiple input of Bluetooth amp
Model DA2120C
Output Power 2 × 125W at 10% THD+N Into 4 Ω
2 × 100W at 10% THD+N Into 6 Ω
2 × 80W at 10% THD+N Into 8 Ω
Bass frequency 20Hz-200Hz
THD ≤ 0.01%
SNR ≥ 105dB
USB Chip Cmedia CM6642 SUPPORT 24bit/192Khz
Amplifier Chip American TI TAS5352A
Bluetooth Chip Qualcomm QCC3031 Bluetooth 5.0 chip supports aptX, aptX-HD, SBC, AAC
DAC Chip American Cirrus CS8422 chip USB, coaxial optical fiber Supported sampling rate 24bit/192Khz
Device Dimension L180*W130*H38mm (7*5*1.5in)
System Supported XP/W7/W8/W10/MAC/Linux
Power Supply 32V 5A
DA2120C Amplifier x 1
32V 5A Power Supply x 1
Remote Control x 1
USB Cable x 1
Optical Cable x 1
AC Cord x 1
DownloadDA2120C User Manual
Based on 9 reviews
44%
56%
(5)
David Fox
Could be better
Sound is ok, missing a treble and base refinement, those are little filtered or dial down. Also missing a passive subwoofer output.
s
szfq93
Great amp and great power
I needed an amp with bluetooth and USB input. I also wanted to get a decent power supply (my previous one came with a weak power supply which didn't give me the sound punch I desired). This Fosi Audio DA2120C met all my needs. I do wish it came with a slightly longer USB-B to USB-A cable.
Steven Kuznicki
Cute Phono Amp
A bit underpowered for what I was expecting. I basically need to run at 90-100% volume to get enough to fill the room. This is more ideal for small room and background music.
Han_So_Oh
Best "soundbar replacement"
Pair this device with a pair of quality bookshelf speakers on stands, and a subwoofer. You've got a setup that beats just about all the popular soundbars out there.
It's so small it fits under the TV on OEM feet. Feels surprisingly heavy for it's size, despite the PSU being external. Binding posts took full size banana plugs with ease. Has every connection possible to cover most TV outputs.
Deducted one star because you will see sparks if connect the PSU while it's plugged in. TBF, every Class D micro amp I've owned does this too.
z
zoxy1955@gmail.com
da2120c
The DA2120C is one of my first Fossey amplifiers.
A complete amplifier with DAC and Display and remote with optical and coaxial inputs and a subwoofer output. All in one amplifier.
At one time I suggested to Fosey to make the same amplifier with improved characteristics as the PRO model.
I still think that it would be a real hit because it is an exceptional amplifier and visually the most beautiful amplifier of all the models.
With the reviews that would follow, it would really be a great success and many people would be interested in having such an amplifier.
