Fosi Audio Box X5 Phono Preamp for Turntable
$104.99
+ Free shipping
MM&MC Cartridges Support
4-Level Gain Adjustment
RIAA Equalization Accuracy
Quantity
Free shipping
Money-Back Guarantee
Customer support
Fosi Audio P4 Mini Preamp with 3 RCA Inputs, EQ/Bypass, Treble & Bass Tone Control with Remote Control
$99.99
$109.99
Fosi Audio Gold-Plated 2 RCA Male to 2 RCA Male Stereo Audio Cable for Home Theater Systems/Amplifier/Preamplifier
$15.99
Matt Coykendall
Can This Cheap Preamp Actually Cover My Needs? Fosi Box X5 Review
United States of Analog
Is This The BEST First AUDIOPHILE UPGRADE For YOUR TURNTABLE? Fosi Audio Box X5 Phono Preamp Review
My Own Devices Audio Channel
The Amazing $109.99 Fosi Audio Box X5 Phono Preamp
Embrace the Vintage Charm of Vinyl with Modern Precision
Input: MM/MC RCA; Output: RCASNR≥92dB; THD≤0.009%
Frequency Response: 20Hz-20kHz(±0.015dB)
Input Voltage: AC 16V
Accurate RIAA Equalization
Ensuring clarity and detail in every note for a rich listening experience.
Audiophile-Grade Components
Carefully selected top-tier components are dedicated to crafting extraordinary sound quality.
Replace with DIP8 dual discrete op-amps, meeting your pursuit of a personalized audio experience.
Connection and Usage Diagram
Plug-and-play convenience, ensuring optimal performance for easy setup.
  • Multiple Gain Settings: With 4-Level gain adjustment settings of 38/48/56/66dB, the preamplifier accommodates both MM & MC cartridge types, meeting a variety of needs. This enhances your phono stage and helps in rebuilding the vintage stereo sound
  • Input Mode: MM+MC RCA
  • Output Mode: RCA
  • THD: ≤0.009%
  • SNR: ≥ 92dB
  • Power Supply: 16V/1A
  • BОX X5 Phono Preamp x 1
  • 16V 1A Power Adapter x 1
Based on 32 reviews
94%
(30)
3%
3%
Raphael Meier
Powerfull & affordable Phono Preamp
Its well built and makes a very solid impression. Sound is clean without any flaws.
Maksym Byvshev
Good built quality
John R. Pedro
Excellent
Great quality, reasonable price....and NOT plastic!
Menno van Rij
Small size, great performance
My latest from Fosi: the Box X5 to amp my Thorens turntable. And man, does it work. Better than expected, I guess. Crisp, clear.
Recommended!
Alan C
The X5 really is that Fabulous
I’m sure you’ve done your own research and know the hype. I’ve been listening to the X5 for past few days now and I am very impressed.
The separation and detail picked out is just tremendous. My set up is AT-LP120x with VM95E to the Fosi . Then to a Denon amp. The X5 really does punch above its weight.
Excellent!!
