Limited-time offer: 15% Off w/ Code LTFA15
- The Best Bluetooth Audio Receivers of 2025
- Output Power: 300Wx2 @4Ω
- Terminating Impedance: 2-8Ω
- Input Mode: Bluetooth + RCA
- THD: ≤0.005%
- SNR: ≥108dB
- Chip Set: TPA3255
- DC Input Range: 24-48V
