Front Side
Back Side
Power Variability
  • Output Power: 300Wx2 @4Ω
  • Input Mode: Bluetooth + RCA
  • THD: ≤0.005%
  • SNR: ≥108dB
  • Chip Set: TPA3255
  • Bluetooth Antenna x 1
100W x2
Bluetooth + RCA
Passive Speakers
≤ 0.04%
≥98dB
TPA3116 x2
24V/4.5A
From $69.99
2.0 CH Amp
Based on 164 reviews
83%
(136)
13%
(22)
Ben Blumanstock
Sal Patel
Sick as amp
Tiny unit but sure plays hard, runs 2 orb audio speakers and a mini 8inch subbie from orb as well and no trouble playing crystal clear, - this review is on the 20A pro but I actually ended up with the 30d Pro as the sub is passive but it is awesome would highly recommend
Logan
Fantastic Amp
The BT20A Pro with the 48V power supply drives a pair of 8 Ohm Kenwood LSK-704s with ease. Fills my lab with plenty of clean sound. Will be coming back for more products
Zachary Powers
Amp works great, very compact & powerful package
The amp packs a lot of punch in a small little footprint; it was very experience but delivers good clean power, especially paired with a 48V 10A power supply. I personally bought the power supply from their competitor Aiyima because they offered a GaN power supply in the 48v 10a variant & it was $40 cheaper than Fosi’s 48v 10a non-GaN psu.
I hope in the future fosi makes a 48v 10a GaN psu to go with this amp in a little cheaper version. But have been very happy with my amp; it takes up a tiny footprint which was really important for me because I use it with my computer & therefore it sits on my desk
Terry Tom
