  • The 48V 5A GaN power supply unit is specifically designed for use with amplifiers and is ideal for providing reliable power to Fosi Audio amplifiers, such as BT20A Pro, TB10D, V3 and ZA3 amplifiers.
  • An amp's excellent performance is inseparable from the blessing of a high-quality power supply. This gallium nitride power supply unit has a power output of 240W, allowing your amps to be fully driven. The overload and over-temperature protection escorts you to enjoy music continuously and stably.
  • With an exquisite body, excellent workmanship and outstanding energy efficiency, the 48V GaN power supply unit will complement Fosi Audio’s high-performance mini amplifiers.
    Input: AC 100-240V
    Output: 48V/5A, 240W
    Compatible Amps: V3, BT20A Pro, TB10D, ZA3
    Total Length: 286cm
  • 5 stars: 18 (69%)
  • 4 stars: 7 (27%)
  • 2 stars: 1 (4%)
RJV (United States)
Exact same part number and size of non GaN?
Concerned I may have received standard 48 volt units since size is same (GaN described as smaller) and has the same part number.
And, no discernible sonic advantage.
Dominique (Canada)
Just perfect
Perfect for my set up with my Fosi BT20A Max amp.
Love the Fosi products
Dominique (Canada)
Just perfect
Hans (United States)
Fosi Audio 48V GaN Power Supply
Fantastic Power Supply, using it with the Fosi Audio V3 - very happy.
Martin (Serbia)
Good product, good service
I had trouble with a local distributor intentionally sending me a broken product, which I then had to return. I contact Fosi HQ, they courteously offered apologies, and explained that and how I could order direct with them and offered a discount even. The package arrived quickly and was properly packaged and sealed. Happy with the product and service.
Martin (Serbia)
William (United States)
I ordered this power supply with a ZA3 power anmolifier and a Fosi DC power filter. It’s compact and stays cool under load and well made with high quality cables.
I ordered this power supply with a ZA3 power anmolifier and a Fosi DC power filter. It��s compact and stays cool under load and well made with high quality cables.
Jonathan (United States)
Quality product
I bought it twice on Amazon and both times received what seemed to be used products. I returned them both and ordered direct from Fosi and received a new one. I'm not sure it makes a difference in my system, but it stays nice and cool and is well built. If nothing else it should last longer than the standard power supplies and as a bonus you may save a few pennies a year.
Quality product
Jonathan
Quality product
Massimo (Italy)
Stabile ed affidabile
Da oltre un anno tengo costantemente collegato alla rete questo alimentatore connesso al mio piccolo amplificatore BT20APRO che uso in cucina con due casse Kef. Devo dire che non mi ha mai deluso. E' stabile, silenzioso e non si surriscalda. Ritengo affidabile al 100%
Massimo (Italy)
Francois (South Africa)
GAN power...
I didn't notice the power lead change when I ordered the power supply, so now I have the older one with a figure 8 plug and the new one that has the earthing point.
They both work very well and the power supplied is balanced.
GAN power...
Kevin (United States)
Item received in good condition and as advertised. Customer Service also was a big help.
The power supply I ordered arrived in good condition and working order once I received it. Supply works exactly as advertised. This order got hung up in US Customs handoff to the Post Office and it appeared to be lost. However Fosi Customer Service got engaged and somehow spurred finding the package and getting it moving from Customs to the Post Office for delivery. Their help was greatly appreciated.
Calvin (United States)
New to Audiophilism
Got the Fosi Audio ZA3 with the 48V GAN Power Supply and the ZD3 to go with a Wiim Pro Plus, through GR Research crossover modded Neumi BS5s... and it all sounds exquisite! Quality components at real people prices!
New to Audiophilism
Michael (United States)
Worked very well for my Aiyima A08 Pro driving 2 8" Cambridge Soundworks drivers in undersized enclosures I bought on Amazon and lined the walls with damping material and stuffed with cotton in an attempt to compensate for the enclosure being undersized. This power supply definitely gave them quite a bit more punch than the stock power supply. I first tried a Skuaike 48 volt power supply but was very disappointed with the noise they produced going through my speakers. I am also using these for two Aiyima AO7 Max's. There is still some noise through the speakers but not nearly as noticable as with the Skuaike power supply. I'm sure the noise is not helped by the wiring in the house I live which is over 100 years old.
Duane (United States)
Clean power Small profile
Its is a good power supply that conforms to all standards.
Craig
It costs more than the TB10D and took a long time to get, but it's a game changer. Definitely worth it if you have high draw speakers.
Craig
