Fosi Audio BL20A Bluetooth TPA3116 2.0CH Sound Power Amplifier 100W Mini HiFi Audio Class D Amp Bass Treble With U-Disk Remote Control
Fosi Audio BL20A Bluetooth TPA3116 Sound Power Amplifier 100W Mini HiFi Audio Class D Amp Bass Treble With U-Disk Remote Control
Fosi Audio BL20A Bluetooth AMP
Fosi Audio BL20A Bluetooth TPA3116 Sound Power Amplifier 100W Mini HiFi Audio Class D Amp Bass Treble With U-Disk Remote Control Media 1 of 7
$69.99 USD
$69.99 USD
$79.99 USD
  • Fosi Audio BL20A is a powerful Bluetooth 5.0 HiFi stereo amplifier with AUX pre-output, which can be used as a pre-amplifier. Design Treble & Bass control and remote control to meet your more needs.
  • The BL20A power amplifier supports AUX/U-Disk/Bluetooth input, suitable for most home passive speakers. Using two low-distortion TPA3116 high-performance chips to display ultra-high-definition sound quality.
  • Let's join the audiophile’s music journey with Fosi Audio BL20A Amp!
Model BL20A
Chip Set TPA3116*2
Output Power 100W x 2
Terminating Impedance 2-8Ω
Input Mode Bluetooth, AUX, U-disk
Output Mode Speaker’s Output + 3.5MM AUX Pre-out
Frequency Range 15Hz-20kHz (±1 dB)
THD ≤0.001%
SNR ≥92dB
Input Sensitivity ≤500mV
Support Format MP3/WMA/APE/ FLAC/WAV
U-Disk Capacity MAX 32GB
Bluetooth Transmission Distance Up to 164ft/50m
Device Dimension 3.54×4.72×1.18 inches
Product Weight 0.71lb/323g
DC Input Range 12-24V
Power Supply 24V 4.5A
BL20A Bluetooth Amplifier x 1
Remote Control x 1
24V 4.5A Power Adapter x 1
AC Cord x 1
We will send the correct plug type according to destination Country
DownloadBL20A User Manual
You can also check our BL20C 160W x2 Bluetooth 2.1 CH Amplifier.
Based on 10 reviews
80%
(8)
10%
10%
Raj Kishor
Amplifier is powerful
Amplifier has good potential and powerful but some cons are there such as on off switch and heat issue after some time of use otherwise amplifier is good enough for good bass
Mohamad Nabil Hijazi
Good Product
Good product for my application. I hope some time to upgrade the BL20A to have screen for track indication, and output LEDs and volume indication to 100% suit my application. I am Mohamad Nabil Hijazi, bought so far 10 units and using it for electromagnetic coils
Stouf
Mauvais son
branché sur 2 enceintes cabasse, le son est médiocre!
Gillad Ben Harosh
Value for money very good
Eitan Goodman
Very happy with the BL20a
Just received the BL20A and am extremely happy with the product. This is my second Fosi amplifier, And I love that it shows up with its own name among my Bluetooth devices so as to not confuse itself with other Fosi products. The remote control is a nice touch as well. And the Bluetooth stays on and ready as long as the amp is plugged in, which makes for very convenient pairing whenever you want to play music. The sound quality delivered through my Dayton bookshelf speakers needed a bit of adjustment at first - but that’s kind of the idea with the BL20a model, it’s more for the control freaks. Though even if you’re not well-versed in sound, it’s very easy to adjust the dials to reach the signature you’re looking for. Now I’m enjoying crisp, balanced sound with good punch. Will definitely recommend this product based on my experience so far.
