Fosi Audio Box X3 Bluetooth Phono Preamp for Turntable Phonograph Preamplifier With 5725 Vacuum Tube
$79.99 USD
$79.99 USD
$79.99 USD
Model BOX X3
Output Interface RCA output
THD ≤ 0.1%
SNR ≥ 98dB
Product Weight 0.71 lb/320g
DC Input Range 12V
Power Supply 12V 1.5A
Box X3 Phono Preamp x 1
5725 Vacuum Tubes x 2
12V 1.5A Power Adapter x 1
RCA Cable x 1
Download BOX X3 User Manual
Based on 5 reviews
40%
20%
40%
Yuwei LIU
Good enough for this price
Drx
Almost satisfied
Pedro Aragão Barros
Kevin Blanc
Great device, amazing support
Great product!
My only issue was solved by the amazing support staff, works like a charm and sounds great!
Robin waters
I like it but I'm going to have to play with it to find the optimum set up through my amp
