$99.99 USD
$99.99 USD
$109.99 USD
  • High-Performance Amplifier
  • Connect Passive/Powered Speakers, Passive/Powered Subwoofers
  • Supports SUB frequency, SUB Volume, Master Volume/Bass/Treble Control
  • Replaceable Knobs: Orange Knob
MODEL:
THD: ≤ 0.03%; SNR: ≥ 108dB; Frequency Range: 20Hz - 20kHz (±1 dB)
MAX Power Output: 165W×2+350W; Input: Bluetooth + RCA; Input Sensitivity: ≤ 600mV
Output: Passive/Active Speakers+ Passive/Active Subwoofer
One Device for All Needs
Reliable power amplifier suited for high impedance speakers and subwoofer
Stable Connectivity
You will have crystal clear audio even over Bluetooth and the range is easily more than 15m.
Ideal for Your Subwoofer
Incredibly powerful bass that stirs up thousands of waves.
Max Output Power 165W×2+350W
Two advanced chips ensure pure and powerful sound with great clarify and separation.
All-Aluminum Alloy Chassis
This little Amp comes nicely packaged with a solid feel to the case and the controls and connectors.
Knobs designed for subwoofer
Pre-Out Connector
  • High Power with Exceptional Sound Quality:Equipped with two high-end Texas Instruments TPA3255 Class-D amplifier chips, the amplifier home audio delivers clear and pure sound without distortion or clipping, stably outputting up to 165W x 2 + 350W of power.
  • Bass Beast:Whether you're a gamer, movie buff, or music lover, the subwoofer amplifier provides tight, smooth, and natural - sounding bass. It features two dedicated knobs for subwoofer control: the SUB FREQ knob allows precise frequency adjustment of passive subwoofers from 0 to 300 Hz, while the SUB VOL knob lets you set the desired volume level. This gives you full control over the bass output to suit your personal preferences and listening environment.
  • Bluetooth 5.0 Connectivity:This Bluetooth amplifier, which automatically reconnects to the previously paired device when turned on. It maintains a stable connection and delivers clear audio over a range of up to 15 meters. This makes it perfect for enjoying your favorite tunes or audio content in outdoor areas such as your yard, terrace, or poolside, without worrying about signal drop - outs or interruptions.
  • Exquisite Craftsmanship:This mini amplifier is meticulously crafted with a solid, all - metal body that ensures durability and longevity. The well - designed case, along with the high - quality controls and connectors, exudes a sense of premium build and attention to detail. The exquisite packaging further adds to the overall appeal and value of the bass amp.
  • Output Power: 165W x2+350W@4Ω
  • Input Mode: Bluetooth + RCA
  • Output Mode: Passive Speakers/Subwoofer + AUX
  • THD: ≤0.03%
  • SNR: ≥108dB
  • Device Dimension: 6 x 5 x 1 inches
Based on 55 reviews
76%
(42)
15%
(8)
5%
4%
David Fox
Better than expected
Crisp sound and fine tuning controls for subwoofer also for treble and bass, great compact amp =)
Steve
Best amp ever but ours overheats
We use ours a lot in a tropical climate and when you turn it up it overheats and locks out. Drilling some holes in the case helped a lot and ultimately putting a fan on it solved the problem. This is one that shipped when it first hit the US market. So they may have corrected something since.
But ours even idles hot. It's weird, our other 3255 mono amp doesn''t feel hot when idling and a friend who visits from another country reports that his BT30D Pro (he bought on my rec) doesn't run hot. But ours does.
Charles Peterson
Bantamweight punching into the middleweight class!
I was excited to get my BT30D Pro and see if I could live up to the hype. I'm needing it for its Bluetooth connectivity and amplification for a vacation home. I already have a great speaker set, Sound Dynamics 300ti, and a some Transparent "wave" cables. It took only 5 minutes to set this station and crank up the tunes.
First, the Bluetooth receiver. Absolutely fantastic. I'd walk all around the house and back porch and never heard the receiver drop out. Great reception.
Then the amp. I'm shocked an amp that resides in a box of roughly 5"x7"x1.5 inches (my estimate)can drive my speakers as well as it does.
All told, this Fosi preamp/amp exceeds my engineer stringent expectations.
HARIF MC
Stephen Burke
Meet my expectations
Sounds great I wish I purchased the 2 sets of speakers amp
