Features:
1.HiFi headphone amplifier and DAC, delicate, compact, lightweight, and portable, which make it convenient to carry, can output remarkable sound without distortion.
2.16-300Ω HiFi headphone amplifier, it is delicate, compact, lightweight, and portable that can be carried conveniently.
3.HD3PRO have used SA9227 and ESS9038Q2M,DSD256 support,384K/32Bit
4. 3.5mm AUX and 2.5 balance output, SNR>120Db and THD+N 0.0003%, make it possibility to output not just louder sound, but a sharper and more real stereo sound without distortion.
5. Aluminum matte surface, fashion design provides you a comfortable handheld feeling while the aluminum matte surface makes it durable.
6. Rechargeable lithium battery, it adopts a rechargeable lithium battery with 1500mAH capacity, which allows it to stay working more than 8 Hours.
7. Universal compatibility, it can remarkably compatible with a various of digital devices, such as mobile phone computer.
Highlight:
- Model: HD3PRO
Maximum power output:400mW in Impedance 16Ω
Load impedance: 16-300Ω
Amp Internal Voltage: ±5V Charging
voltage: DC5V
Frequency response: 5Hz-25kHz(±3dB)
Battery capacity: 1500mAh (3,7V) Lithium-Battery
Amp Using Time: More Than 8 Hours
Distortion: 0.004%
SNR: ≥120dB
Dimension(L*W*H): 4.5*2.4*0.6inch
Net Weight: 100g
Package Include:
*1 x Headphone Amplifier
*1 x USB Power Cable
*1 x User's Manual
*1 x mirco decode cable
*1 x typec decode cable
