Fosi Audio K5 Pro Gaming DAC Headphone Amplifier Mini Hi-Fi Stereo for PS5/PC/MAC/Smartphone
$79.99
+ Free shipping
Added microphone with multi-functions
Compatible with various devices
Converts multiple audio signals well
High-quality sound with chips
Quantity
Free shipping
Money-Back Guarantee
Customer support
$69.99
Fosi Audio XR-D5 DAC AMP 16-300Ω ESS9018K2M Decoder Headphone Amp(Refurbished Unit)
$67.49
Free shipping
Support 24/7
Easy Returns and Exchanges
Fosi Audio SP601 Orange Version Passive Bookshelf Speakers
Lorem ipsum dolor sit amet, consectetur adipiscing
(20)
$399.99
4 interest-free payments of $15.00
Lorem ipsum dolor sit amet, consectetur adipiscing elit.
Ut enim ad minim veniam, quis nostrud exercitation ullamco.
Duis aute irure dolor in reprehenderit in voluptate velit.
Quis nostrud exercitation ullamco laboris.
Ut labore et dolore magna aliqua.
see what they’re saying
professional reviews
MIND THE HEADPHONE
Diversión con Vinilos
cheapaudioman
Make Life Click
the upgraded version of Fosi Audio Q4
Input: USB-C/OPT/COA/3.5MM Microphone; Output: RCA/3.5mm Headphone;OPT/COASampling Rate: up to 24bit/192 kHz;
Output power: 1000mw@16Ω, 500mw@32Ω, 300mw@64Ω, 150mw@128Ω, 80mw@300Ω;
THD: <0.003%; S/N: >110db; Frequency response: 20Hz-20kHz;Recommended headphone impedance: 16-300Ω
NEW DAC Headphone Amp
RCA output can be connected to an amplifier or powered speakers on your desktop.
Exclusive Design with Independent Mic Input
Converts USB Type C/Optical/Coaxial signals to 3.5MM AUX and RCA signals with low distortion
Gaming Starts Here
Enjoy the realistic auditory experience in every detail
Stereo DAC Headphone Amplifier
K5 Pro can drive 16 Ohm to 300 Ohm headphones with low distortion and great dynamic range.
Desktop DAC and Headphone Amplifier
The knobs are high quality and turn very smoothly, they’re quite enjoyable to use.
Mini Stereo Gaming DAC
Great Value Headphone AMP/DAC with Bass/Treble Control
Gaming Starts Here
  • The upgraded version of Fosi Audio Q4 adds microphone function, K5 Pro headphone DAC amp combo, next-generation audio converter with unrivaled internals, more outstanding performance, and richer audio details. Born for Gaming. K5 Pro stereo DAC headphone amplifier is perfect for your home gaming system, equivalent to an external sound card, suitable for PS5/Computers/PC/MAC/active speakers, etc.
  • K5 Pro USB DAC converts USB Type C/Optical/Coaxial signals to 3.5MM AUX and RCA signals with low distortion and great dynamic range. Unique design: 2-in-1 USB Type C interface charging port and audio input means K5 Pro is compatible with your phones(Note: Your audio source must be connected to the USB-A/C port.). RCA output can be connected to an amplifier or powered speakers on your desktop. 3.5 MM AUX and microphone interface can drive 16 Ohm to 300 Ohm headphones.
  • K5 Pro headphone DAC adopts the Texas Instruments NE5532 op-amp chip. The circuit design implementing this DAC has been optimized for a low-noise floor and clean sound. K5 Pro has noticeably improved on overall sound quality, so you can get immersed in your music even more easily. Volume button and on button are combined into one, long press to switch on.
  • Product Specifications: K5 Pro with master volume/bass/treble control and input mode switch. USB Type C rate: up to 24 bit/96 kHz, Optical/Coaxial sampling rate: up to 24 bit/192 kHz, THD ≤0.003%, SNR ≥110dB. Output power: 1000mw@16Ω, 500mw@32Ω, 300mw@64Ω, 150mw@128Ω, 80mw@300Ω.
  • What You Get: K5 Pro DAC amp x1, 3.5MM headphone splitter x1, 2-in-1 USB Type A/C to Type C cable x1, User Manual x1, Optical Cable x1, our worry-free 24-month warranty, and friendly customer service
  • THD: <0.003%
  • SNR: ≥110dB
  • Net Weight: 0.55lb (251g)
  • Power Supply: 5V
  • Fosi Audio K5 Pro x 1
  • USB Type-C cable x 1
  • Optical cable x 1
Based on 49 reviews
84%
(41)
10%
(5)
4%
Michael Choi
Great amazing, adds tremendous value
These add tremendous value to planar headphones. Total sound immersion, a world of value
Volker Wach
Fosi Audio K5 Pro.
Hello, I am very satisfied with the Fosi Audio K5 Pro.
James Lu
A good value DAC
I have using this device mainly as DAC with RCA out to ZA3 and sometimes as headphone DAC.
Good - Build quality is pretty good in general, but the bass and treble nobs are slightly off centre. Sound profile is quite neutral, with bass and treble adjustments you could tailor to your liking. It is features rich with pretty much all the outputs for a DAC except Bluetooth, which is usually not great with the basic codec.
Not so good - the gain is quite low for RCA out, you will need to push the DAC to 3 o'clock just to get to normal listening volume, it might be too low for anyone if looking to crank things up. USB input doesn't sound as good as the other inputs.
In Summary - if you are looking for good value and reasonably good sounding DAC + headphone DAC then this could be a good option to consider.
Matej Miljko
Nice device, with a few issues
I like the device, it does what it is meant to do, but...
The front power on led is very bright so I turn the device off at night when not in use. Every time I power it back on I get a USB device descriptor failed error and it is not detected untill I power cycle the device again. Quite annoying.
Red Panda
Amazing
if you turn the amp up all the way you may hear a bit of static, although this is very very faint and you will not hear it while playing any sound or music
