  • Pro Splitter Amp: The PH05 is a versatile one-in-five-out stereo headphone splitter/amplifier, allowing you to connect up to five sets of headphones simultaneously, adapting to multiple audio-sharing and distribution scenarios. Whether for professional music studio production, podcasting, teaching, or everyday use like seniors watching TV, it will serve as your excellent companion.
  • Independent Amplification: Each of the five channels can independently output power up to 310mW@32ฮฉ, perfectly compatible with a variety of monitor headphones and IEMs with impedance ranging from 16 to 300 ohms, providing flexible audio sharing. PH05 is an upgrade model of PH04 which offers one more channel and higher power output.
  • User-Friendly Control: Equipped with independent level control knobs for each channel, ensuring that adjustments made to one channel do not affect others, allowing personalized volume settings for each headphone. Additionally, features a large-diameter master volume control and a one-touch mute button, greatly enhancing ease of use.
  • Outstanding Performance: In addition to delivering robust power output, the PH05 boasts an advanced circuitry design internally, ensuring pristine sound. With an SNR of up to 105dB, THD as low as 0.001%, and noise floor as low as 25ฮผV, it guarantees exceptional audio fidelity.
  • Substantial & Compact: The perfect combination of all-aluminum alloy solid build, exquisite appearance, anti-slip foot pads, and greater stability. Experience the superior quality in every touch, complemented by the peace of mind that comes with Fosi Audio's 24-month warranty.
Didnโ€™t find your answer?
  • 5 stars: 16 (100%)
  • 4 stars: 0 (0%)
Paul H.
High Quality Headphone Splitter
Great way to compare headphones with different sensitivities. Transparent and powerful enough for the use case. Another impressive headamp from Fosi
Paul H.
Jay P.
Impressive
I was very surprised by Fosse audio PH05 five channel headphone amplifier. For the price the quality is amazing. Sound quality is excellent. Crafted like something much more expensive.
Jay P.
Impressive
m
mehmet k.
Very nice
The sound is of the quality I expected, the material is also of very high quality, it will be very useful for me, thank you fosi audio
m
mehmet k.
Very nice
Very useful for sharing
Share your audio like anything
Tony L.
Multi Channel Amp
Excellent. Really enjoying comparing IEMs. Makes the process much easier. Clean and powerful amp. Recommend...
Tony L.
Multi Channel Amp
D. T.I.
Great multi-output amp/splitter
After juggling multiple monitors on one output for years, this thing rocks! I'm only using three outputs right now. Two headphones and one amp. The individual volume controls allow me and a guest or guests to listen to the same thing at our own volume. I can then turn the headphones down and use my amp when headphones aren't necessary. It even seems to sound cleaner than my old setup.
D. T.I.
Mark P.
Fantastic value
Excellent headphone amp to be able to switch to different headphones with ease.
Mark P.
Fantastic value
Bill
Awesome little device
Bill L.
