NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
  • Channel : 1.0
  • Input : RCA, XLR, ¼" TRS
  • SNR : ≥123dB
  • Dynamic Range : ≥123dB
  • THD : <0.006%
  • Terminal Impedance : 2-8Ω
  • Standard PSU : 48V/5A
From $109.99
300W@4Ω
RCA, XLR, ¼”TRS
Speaker Output
<0.006%
≥123dB
From $109.99
2.0 CH Amp
RCA, XLR, ¼”TRS
Speaker Output, Sub-Out
<0.006%
≥106dB
From $69.99
2.0 CH Amp
Passive Speakers, Pre-Out
≥ 108dB
Fosi Audio M03 Subwoofer Mono Amplifier - Fosi Audio
From $76.49
Subwoofer Amp/MoxAmp
200W
≤0.03%
≥ 106dB
4-8Ω
32V/5A
Customers praised the V3 Mono's exceptional sound quality, "incredible clean power," and "excellent value." Many noted "They sound great" with "wide soundstage" and strong bass control. However, several mentioned the units "run super hot" and recommended separate power supplies for each amp. Some experienced shipping/delivery issues.
  • 5 stars: 167 (83%)
  • 4 stars: 26 (13%)
  • 3 stars: 6 (3%)
  • 1 star: 2 (1%)
Love them like a fat kid loves cake!!!! I think
Love them like a fat kid loves cake!!!! I think these are such a great value and as soon as you upgraded the op-amps you turn them into truly amazing little amps. They do great on their own, but trust me when I say both the V7 classics or the Sparkos give these little amps a sound with $1,000+ minimum. Don’t thing, just get them and thank later.
A (Canada)
Amazing product
My friend had gotten two of these for me and it works very well. My setup is similar to the picture I've attatched!
Paulo (Portugal)
Excelent Little Monster!
I have a pair of speakers from B&W 805S and they have some considerable variations on impedance across frequency.
I buy a pair of Fosi Mono V3 AMP mainly on expectation that PFFB could "tame" the load.
Et voilá, I used previously Fosi ZA3 (no PFFB) and, although excelent it had some small harshness on higher frequencies.
The Monos V3 done an excelent job even with the stock opamps.
So very pleased with them!
Later I changed the opamps to LME49720 and increased this smoothness even more, without loosing any detail.
Recently I swapped the opamp #2 to the Sparkos SS3602 and gained speed and transient response without loosing anything.
This is now my choice o AMP and recommend it to anyone.
- Lot's of power
- No sign of distortion
- Effective load variation independence
Anonymous (Indonesia)
Love
I love the sound output
Flo (Germany)
Preis / Leistung Top
Bin super zufrieden; Sound und Leistung sehr gut. Einzigste Manko tatsächlich die Hitzeentwicklung. Das lässt sich aber mit aktiver Abluft lösen.
Petter (Norway)
Great sound quality and performance
I got this recently and it took my setup from 0 to 100 with the sound.
Slavisa (France)
Great mono AMP V3
Using this dual mono V3 amplifiers for a more then 1 year now. Only what i can say it is really perfect for my taste. Lots of powers. I am paired them with Infinity reference 61 mk II speakers. Really great product this 2 mono. My recommendation
JS (United States)
Small but Powerful
I'm using a pair of V3s to drive vintage 16 ohm Altec Lansing speakers through my Fosi P4 preamp. They provide plenty of power and deliver crystal clear audio! I love them.
S.G. (Spain)
Still amazing
More than one year after buying a pair in the pre-launch campaing the sound of these little gemes still amazes me
Martin (United States)
Impressed
Been using my v3 amps for a few months now. They are clean crisp and sound great. No noise and provide plenty of power to drive my Polk towers. Whats amazing is how small they are. They do get warm but nothing alarming.i did put my amps on an acrylic stand with a few Fosi fans to cool them during long listening sessions. The auto power feature works great - less to turn on and off!
Bence (Hungary)
Amazing amplifiers.
I also ordered a p4 preamp for the v3 mono pair. I bought them for a Dali Lektor 8. When I first turned them on, I set the gain to the lowest on both amplifiers, but at first hearing this wasn't enough for the dynamics and I raised the p4 gain from 3 to 6. This proved to be good for the first few days, but after a while the bass started to get tighter (disturbingly) so I set it back to 3. I think it took a while for the set to get used to it. Since I've had the p4 on 3 again, it's as if the speakers needed a new lease of life. Those amplifiers have brought an amazing improvement compared to the previous Sony FA3ES.
Eric (United States)
Awsome
What great dound and power. Thank you fosi. Cant wait to get my luna turn table.service is outstanding.
Impressed
Really impressed with the performance of my v3 mono blocks. Moved from a large underpowered integrated amp to Fosi class D mini components and wasn’t sure what to think. But these two little amps really drive my hard to power speakers!
DocHouse (Germany)
Hot Stuff
Hot stuff but very cool sound
Keith (Australia)
Problem solved.
Alex (United States)
Donnie (United States)
V3 monos
William (United States)
Best bang for the buck amps I have found
Was looking for a desktop setup to replace my Schiit Vidar monoblocks. These sound every bit as good but are much smaller and a fraction of the price. The TPA3255 is an amazing chip and Fosi have built an incredible amp around it, at a price that is unbelievably good. I'm using them to power my LS50 Metas and they have plenty of power to push them to uncomfortably loud levels. I upgraded the opamps to Sparkos SS3602, which was definitely an improvement, but it nearly doubles the cost of the system, so I'm not sure I would recommend it. The amps do get hot because they use the chassis as a heat sink. It was a little concerning at first but I've been running them for almost a year with no issues.
Phil (United States)
Little footprint, Big kick!
I love these little guys. They’ve easily powered every speaker I’ve thrown at them including B&Ws.
Dylan (United States)
Would recommend, but positioning may be troublesome
Right out of the box, just holding them in my hand I could tell they were well put together little beasts. The switches in front feel really good, and the connectors in the back seemed sturdy. I was a little bit caught off guard by how small the binding posts were and I had a little bit of trouble sticking the bare wire in, and the rotation of the holes for the wire was not the same on both posts (maybe they can be rotated back, but I didn’t try that). I got the package with 1 power supply which splits into two cords, and because the amps are quite light, and the weight and stiffness of the power cords and cord splitter thing is enough to make positioning them a little bit difficult, but once they’re set they’re set. The cord from the wall to the power supply is also very short which makes positioning more strict. But I got them set up and plugged in and they’re working perfectly! They’re powering a pair of Paradigm Monitor SE 6000f speakers and compared to my Denon avr 570 that I had them powered with previously, the bass is so much more powerful and detailed. I don’t want to talk too much on the sound because I haven’t much experience to compare it to since they’re only my second amp. Something I do notice and as have other reviewers online, they can’t get quite warm to the touch when driving at louder volumes. They have never gotten to the point that they are too hot to touch, and I haven’t noticed any degradation to the sound when they heat up, so they must be engineered with the heat in mind. I am very satisfied with these monoblocks and would absolutely recommend them to someone on a lower budget looking for some kick in their system.
