12V Trigger Sync Interface
Logarithmic Potentiometer
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
From $109.99
ZA3 Balanced Stereo Amplifier
2.0 CH Amp
RCA, XLR, ¼”TRS
Passive SPK +Sub-out
<0.006%
≥106dB
From $109.99
300W@4Ω
RCA, XLR, ¼”TRS
Speaker Output
<0.006%
≥123dB
TB10D Stereo Audio Amplifier
2.0 Ch Amp
300W x2
Passive Speakers
≤ 0.3%
≥ 90dB
From $69.99
2.0 Ch Amp
Passive Speakers, Pre-Out
Stereo Mode
XLR Input
Subwoofer Channel
Customers praised this compact amplifier for its exceptional power, clean sound, and excellent value. Many said it delivers "crystal clear" audio with impressive soundstage and detail. The amplifier drives various speakers effortlessly, with some noting it "sounds fantastic" and rivals more expensive models. Common positives include small footprint, balanced XLR inputs, and mono capability. Some concerns: delivery delays, one power cord issue, and occasional service communication challenges.
  • 5 stars: 370 (89%)
  • 4 stars: 34 (8%)
  • 3 stars: 7 (2%)
  • 1 star: 6 (1%)
PIETER (Hungary)
Simple, elegant but made a big difference
Wiim Pro Plus->Topping LS30 II->Fosi ZA3
Opened up a new world of HiFi audio but economically.
I was able to reuse home cinema floor standers and for the first time they sound great.
Adam (United States)
Purchaced this for my office system powering ELAC 3.0
Purchaced this for my office system powering a pair of Elac Debut 3.0 (walnut - do not sleep on these!) and use the subwoofer output to connect to a REL 201 subwoofer. WHAT A COMBO! The ZA3 has copious amount of power. When I hooked up my source (Linn Akurate DS from my previous big rig system) via XLR - the output was actually too much, the voltage diff between the XLR and RCA (what I ultimately ended up using) was suprising on the output side. With the Linn as the source I hear no audible noise or distortion on music, dead quiet when at idle. The signal is also clean with the REL, no hum/grounding issues. Just buy it, it'll suprise you I guarantee it. *edited photo to remove personal info
Jorge (Mexico)
Enorme por el tamaño !!!!
La verdad, el ZA3 me ha sorprendido muchísimo.
Lo tengo integrado en mi sistema junto con el LC30 y conectado a unas Monitor Audio RX6. El ZA3 es el que se encarga de toda la parte estéreo y, sinceramente, no esperaba que un amplificador tan pequeño pudiera sonar así.
Tiene muy buena potencia, mueve las RX6 sin ningún problema y el sonido es limpio, con detalle y con muy buen control. Pero más allá de especificaciones, lo importante es que simplemente se disfruta. Me he encontrado volviendo a escuchar canciones que conozco perfectamente y descubriendo detalles que antes no me llamaban tanto la atención.
Y todavía lo tengo completamente de fábrica. Mi siguiente paso será ponerle los Sparkos, porque tengo mucha curiosidad por ver hasta dónde puede llegar.
Pero incluso sin ese upgrade, el ZA3 ya me parece increíble. Por tamaño, precio y, sobre todo, por cómo suena dentro de un sistema real, me ha dejado más que satisfecho.
Definitivamente es de esos aparatos que después de escucharlos te hacen preguntarte: ¿cómo puede salir tanto de algo tan pequeño?
Andrés (Chile)
Excellent amplifier with impressive power and detail
I've been using the ZA3 in a desktop hi-fi system paired with Wharfedale Diamond 12.2 speakers, and the performance has exceeded my expectations. The amplifier delivers plenty of clean power, excellent channel separation, and a very low noise floor.
The balanced XLR input works flawlessly with my ZD3 DAC, creating a clean and dynamic sound with tight bass, detailed mids, and smooth highs. Even at higher listening levels, the sound remains controlled and effortless.
Build quality is outstanding, the case feels solid, and the volume control has a premium feel. The 48V power supply provides more than enough headroom.
For the price, I honestly think the ZA3 competes with amplifiers that cost significantly more. Highly recommended.
Michael (United States)
ZA3 - Good power for the buck
I've had my ZA3 for a couple weeks now, and I've been really happy with it.
Running it along with the S3 streamer, and it has been powering my bookshelf speakers without a problem! Using the XLR inputs, I get a really clean signal. Really like the 12v trigger, so I can power on my S3 and the ZA3 powers on right along side. Haven't tried rolling op amps yet, but maybe in the future. But I'm really happy with it right now!
John
The Fosi Audio ZA3 amplifier completely transformed my HiFi setup.
The Fosi Audio ZA3 amplifier completely transformed my HiFi setup. It pushes plenty of clean power, and my Elac 3.0 DB63 speakers and B&W ASW608 subwoofer sound absolutely amazing running off of it. The build quality is fantastic, and I’m already planning to complete the ultimate stack by adding the matching Fosi ZD3 DAC and Merak CD player next. Highly recommend!
p
phdejo (Slovakia)
Ben (Australia)
Great value for the price
bought another ZA3 after tried my first one for several months, the extra power of mono/mono configuration improved the sound quality noticeably in terms of dynamics and sound stage for my 4om/200wRMS speakers.
ERIK (United States)
Get two
Get two and run these in mono for L/R, use XLR cables and never look back.
Peter (Hungary)
Simple and powerful
With the 12V trigger and small footprint it is easy to integrate to a convenient and good sounding system. It has enough power to drive my Q Acoustics 3030i and retain a decent headroom. It is also a great option to have a sub out as well. No complaints whatsoever.
Darko (Croatia)
Great in my setup
Using two ZA3 units as monoblocks in my custom 5.1 setup completely changed the system.
The biggest improvement was not just power, but control, separation and effortless dynamics. Stereo imaging became more precise, vocals cleaner and bass tighter without sounding exaggerated.
What impressed me the most is how relaxed and stable everything sounds even at higher volumes. The amps never feel stressed. Small details stay clear while the whole sound becomes bigger and more immersive.
I originally planned to use one ZA3 for center/LFE duty, but after trying them as monoblocks for FL/FR, I immediately kept them that way. The sense of space, instrument positioning and transient response became addictive.
Excellent amps for both music and movies, especially in active or multi-amp systems.
Jay (United States)
Love this!
Decided to upgrade my office music setup and bought this amp (along with the Fosi Audio Box X5 Phono Preamplifier and Fosi cables), and couldn't be happier. Sounds great, was relatively affordable, shipped quickly, and looks cool next to my turntable. Highly recommend.
Anonymous (Indonesia)
Love this one
Idk but this is so good
Mohammed (Oman)
very powerful and clean amplifier
highlr recommended for who like natural and clean sound
Good upgrade path or just go all in?
First time Fosi buyer, never heard them or tested. Was going to just start small and test but ended up getting two of them to use in mono mode, then got the birding audio classic op-amps.
Do to the shipping getting split into multiple packages I first got one and tested it, then took the sub op-amp out and tested, then got the second one and tested with sub and left op-amps out, then got the Burson classic op-amps and put them in.
At every stage I heard a tangible improvement, and now I’m left with one amazing system that is truly impressive, not just for the price but at any level.
Wish I could say the same thing about the Streamer they sell, as that is a complete mess and will leave a review in the future as soon as they fix what is wrong with mine, but this amp is solid and recommended if you can afford it to just go all in from the start.
Cheers!
Peregrine (United States)
Very happy with this purchase!
Amazing performance from such a handsome tiny amplifier. It arrived nicely packaged and in perfect condition. It was easy to set up with the power supply and connections to the Fosi DAC and preamplifier. It’s very pleasant to look at as well as the listening experience. I’m curious about opamp options, but it sounds very good to me right out of the box. I’ll live with it for a while before making any decisions regarding modifications.
Ash (United States)
Small Package, Big Sound
Love it! Wide soundstage, great stereo separation, stays tight even cranked up. Build quality is solid too - the toggle switches have a satisfying click and the volume knob feels premium. Seriously good value for what you're getting.
Ian (Canada)
As good as it gets - so I got two
I bought two ZA3 amps and have them as mono amps and quite frankly I don't think that you can get a better quality setup for the money.
Absolutely delighted with the amps.
Octavian (Romania)
Superb!
Curently I use this amplifier in stereo mode and I am very satisfied. I intend to buy another one for MonoBlock for better chanel separation and for separate 48V power supply. I am in love with the design and sound.
GB (Hungary)
good choice
DGJ (The Netherlands)
Good.
Good amplifier.
