$149.99 USD
$149.99 USD
$149.99 USD
Model:
Shipping to:
PBTL Mono Mode Support
Home Audio System
XLR Input
Swappable Op-Amps
12V Trigger Sync Interface
Logarithmic Potentiometer
  • Output Power:
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
  • ZA3 Power Amplifier x 1
Based on 254 reviews
88%
(223)
9%
(23)
Greg Gauger
Excellent Audio and Value
I replaced my Fosi BT20A with a ZD3 DAC and ZA3 amplifier. Straight out of the box, the sound was clearer and richer. My tip is to use a USB cable to stream music; Bluetooth requires much more and the volume suffers. A hard line to the DAC and you will be impressed. I also feel the quality and appearance are first rate, especially considering the cost! A speaker is always the limiting factor - challenge your best to what Fosi provides!
b
boaz cohen
Fosi Audio ZA3
good bass sound and natoral amp
very nice for home use :)
h
hiwata
The sound is great, and it's fun to have room for personal tinkering.
I replaced the op-amp in the ZA3 with a Texas Instruments OPA1612. The DAC for the ZA3 is the S.M.S.L SU-1. Some people said that the left and right balance was not good when the volume was set low, so I connected a fully balanced passive preamp with an ALPS RK27 potentiometer, although it is not made by FOSI. I am not happy with the fact that the cutoff frequency of the subwoofer output is fixed at 300Hz. So I set the subwoofer crossover to 100Hz using PC software called EKIO and another DAC (TOPPING DX1). I am very happy with this combination.
However, FOSI recently released the Q6, which uses the same AK4493 chip. I think I would have been more satisfied if I had waited a little longer and purchased this one.
p
paul
ZA3 stereo amp is fantastic
It's so good to find quality, value & reliability in the audio gear made by FosiAudio.
Really looking forward to following you guys along the road of success !
p
paul
My perfect amp !
So glad I found FosiAudio on AliExpress, this ZA3 stereo amp is just what I needed to add my passive Floor standing Memorex speakers to the 2nd speaker output of my studio audio interface, it sounds full and satisfying, it looks cool, stays cool & is incredibly good value! A big thanks to all the Fosi team
