  • SNR≥126dB; THD+N<0.00008%
Swappable Op-Amp Design
Bypass Mode
Trigger In/Out
Perfect Match to ZA3 Amp
  • Maximum Sampling Rate:
    USB: PCM 32bit/768kHz; DSD512
    OPT/COAX: PCM 24bit/192kHz
    Bluetooth: PCM 24bit/48kHz
  • Output Level:
    XLR: 5Vrms RCA: 2.5Vrms
  • Output Mode: XLR, RCA
  • SINAD: 126dB
  • THD: ≥120dB
  • THD+N: <0.00008%
  • Dynamic Range: ≥123dB
  • Noise Floor: ≤2μV
  • Bluetooth Version: 5.0
  • Power Supply: DC 12V 1.5A
  • DAC ZD3 *1
  • 12V Power Adapter *1
  • Infrared Remote Control *1
  • USB-A to USB-B Cable *1
  • 3.5mm Trigger Cable *1
  • USER MANUAL *1
From $179.99
DAC Preamp
XLR, RCA
<0.00008%
≥126dB
Chipset
DC 12V/1.5A
From $119.99
DAC+Headphone Amp
250mw@32Ω
RCA, 3.5mm Headphone Jack
>103dB
Chipset
16-300Ω
DC 12V/1.5A
From $199.99
DAC+Headphone Amp
2x 2.1W@32Ω
≤ 0.0002%
≥121dB
Chipset
16-300Ω
DC 12V/2A
From $99.99
DAC+Headphone Amp
1.1W@32Ω
USB-C, Optical
≤0.001%
≥120dB
Chipset
16-300Ω
How to replace the op-amps?
