Fosi Audio K7 HiFi DAC & Headphone Amplifier
$199.99
+ Free shipping
Audiophile-Grade Chipset Integrated
All-in-One Desktop Hub
Input: Bluetooth, COAX, OPT, USB
Output: 3.5/4.4mm Balanced Headphone Output, RCA
Quantity
Free shipping
Money-Back Guarantee
Customer support
$49.99
Fosi Audio Visualizer, Music Rhythm Ambient Light
$49.99
Born for HiFi and Gaming
Poster
The K7 is a versatile gaming HiFi DAC/headphone amp, developed based on in-depth feedback from over a hundred HiFi and gaming enthusiasts. It supports mainstream digital inputs like USB, optical, and coaxial, and is equipped with aptX HD lossless Bluetooth codecs.
The K7 also features a microphone input with noise reduction, ensuring your voice is heard clearly online. Perfectly compatible with PS5 Pro, PS5, Switch, PC, Mac, tablets, TVs, and projectors, the K7 offers balanced headphone and line outputs. It easily handles music listening, gaming, work, live streaming, and multimedia needs. With its compact design and rich functionality, the K7 ensures an exceptional listening and gaming experience.
Reviews are in...
Poster
Poster
Why K7 DAC/Amp?
HiFi and Gaming,
Headphone Amplifier
Pure Music Enjoyment
Best Gaming DAC K7
Gaming Entertainment
Best Gaming DAC K7
Best Budget DAC
Best Budget DAC
DAC Bluetooth Amp
Comprehensive Digital Inputs
with Versatile Outputs
DAC Converter
3.5mm
Single-Ended Headphone Output
Rated Power
≥600mW+600mW @32Ω
4.4mm
Rated Power
≥2.1W+2.1W @32Ω
3.5mm
Microphone Input
Best Bluetooth Amp
Hi-Res
Bluetooth Codecs
Under 40 ms
Imperceptible latency
Lossless PCM 24bit/48kHz
Sampling Rate
1.5-Inch LCD
High Definition Display
User-Friendly and
Practical Control Design
Best Desktop DAC
Tactile Shortcut Buttons
Best Desktop DAC
Best Desktop DAC
Angled Ergonomic Design
Best Desktop DAC
Connection Diagram
All-Aluminum Alloy Body,
with CNC Integrated Design
Best Headphone Amplifier
Best Budget DAC
Best Gaming DAC
Fully Balanced Circuitry,
0.0002% Ultra-Low Distortion
Multiple LDO Regulators
Ensuring Clear Sound Quality
Application Scenarios
General Specs
Chipset
Maximum Sampling Rate
USB:PCM 384kHz-32bit/DSD256
Optical: PCM 24bit/192kHz
Coaxial: PCM 24bit/192kHz
Bluetooth:PCM 24bit/48kHz
Headphone lmpedance
16-300Ω
Firmware Upgrade
Bluetooth Version
5.0
Bluetooth Connection Distance
≤13m
Noise Floor
≤2.5μV
Input Voltage and Current
DC 12V 2A
USB Compatible
Devices
Audio Parameters
Rated Power Output
121dB
<0.0002%
Dynamic Range
121dB
Noise Floor
≤ 6.5μV
Rated Power Output
122dB
0.0005%
Dynamic Range
121dB
Noise Floor
≤2.5μV
Frequency Response
20Hz-20kHz (±0.1dB)
RCA Output
Output Level
≥2Vrms
20Hz-20kHz (±0.1dB)
0.0005%
Dynamic Range
121dB
Noise Floor
≤3μV
Frequency Response
20Hz-20kHz
Packing List
  • The microphone can only be used in USB input 1.0 mode, not in Bluetooth, optical fiber, etc; The microphone is not supported in RCA output mode, only in headphone output mode.
  • Because 2.0 supports higher sampling rates, while the sampling rate of the microphone is only 16bit/48khz. When playing high sampling rates such as dsd or 384khz, if the microphone is turned on at the same time, the two will conflict.
  • Not supported.
  • Yes, K7 has targeted the ambient noise frequency band and has processed it in an algorithm to make your call clearer.
  • After turning on the microphone mute function with one click, the other party will not hear any of your voice.
Based on 7 reviews
86%
(6)
14%
Oscar of the North
Don't let the word "gaming" fool you, this is proper audiophile quality!
Unboxing the device and holding it on your hand, the thing already oozes quality. Plugging this to my PC and pushing some Hi-Res music through this thing to my Sennheiser headset, I could immediately tell the difference to my Mayflower ARC DAC amp. Especially in UAC2.0 and bypass mode, the soundstage in depth, width and height is extraordinarily spacious, and transparent. Excellent bit of kit, and for the price, it's amazing! If you need a headphone amp for your PC, look no further.
Sebas D
Great for gaming and music
Couldn't be happier with this amp. Sounds great with my headphones.
Stos
Complete package
Amazing build quality, functionality, sound and options. It can do it all and at an amazing price point. If your getting into to audio, buy this and you’ll be set.If you are an audiophile, for this price it punches way above its weight and you’d be hard pressed to find something better that doesn’t cost under $1000. Pushes all my high end headphones easily. The mic input is such a welcome addition especially if you have a headset mic you add to your high end headphones. I really couldn’t be happier with this.
Eric Aumont
Wilfredo Otero
Excellent for Sound quality, power, not a wallet killer!
As a gamer, is a dream come true, sound of the K7 did make my disappointing BlackShark headphone sound different clarity, sound, stage , it had more detail, is ok for that BS headphone i'm impressed . I'm only scratching the potential of k7 no doubt music and movie sounded Excellent, i'm looking forward to buy higher quality headphone like the fosi i5 headphone, to really take advantage of k7 i cant commend enough, these guys take engineering serious, that's good.
