- 300W high power Bluetooth 4.0 digital amplifier can offer 150W for subwoofer and 75W for each channe;
- Bluetooth 4.0 high-speed and stable signal transfer; enjoy your music wirelessl;
- Sound is analytical and clear with balanced tri-frequency and no background noise;
- With treble / bass / volume independent control; Standard RCA & Banana jack;
- Unlike others' 19V power supply, we use 24V 6A high-quality power supply; Can be used directly when you received;
Parameters:
Amplifier chip: TAS5613
Bluetooth chip: CSR8635
THD+N: <1%
Signal to noise ratio: >100dB
Input impedence: 20KΩ
Output offset voltage: <150mV
Transfer range: 50V/us
Frequence range: 20Hz ~ 20kHz
External size: 102 * 36 * 138 mm / 4.02 * 1.42 * 5.43 in
Load range: 4 ~ 8Ω
Power range: DC 24V ~ 32V; 5.5mm (internal 2.1mm) plug size
Output power(under DC 35V test): 150W 4Ω / 80W 8Ω (subwoofer); 75W 4Ω / 40W 8Ω (stereo)
Package Includes:
1 * TAS5613 amplifier
1 * 24V 6A power supply
