$49.99 USD
$49.99 USD
$49.99 USD
Color: Gray
CNC All-Metal Zinc Alloy
Remote Volume Adjustment
Infrequent Recharging Needed
Ease of Use
The Volume On-the-Fly
  • VOL20 *1
  • USER MANUALL *1
Based on 18 reviews
72%
(13)
17%
6%
6%
Nick R.
Works decently most of the time.
Purchased a VOL20 BT knob, shipping was pretty quick from something coming directly from China and it seems to work decently most of the time. Construction is tough as nails and the zinc alloy feels good to the touch. I wish you could set a particular color for the RGB. The options are off, constant green, green for 5 seconds then turns off, or spectrum lighting...so I just leave it off. Better on battery as well I'm sure. Maybe Fosi can add a constant color of your choosing in a firmware update though. The biggest problem is that it often disconnects and then searches for a BT signal. I purchased a TP-Link dongle with a long antenna on it which helped a bit, however it still disconnects and searches for a signal every 30 mins or so for about 10-15 seconds until it reconnects. I'd say it's worth purchasing though just make sure you have a good antenna'd BT dongle. By the way, my VOL20 and BT dongle are only like 5 feet a part so I'm not quite sure why it disconnects and researches for the connection. All in all a good product. I'd recommend it with the addition of the BT dongle with antenna. Perhaps Fosi can make a fix in the firmware with that as well over time. No piece of technology is ever perfect.
Mark Hickey
Janky
The knob wobbles.
Morgan Sumner
Elegant solution
Simple to use and response time is almost instant. Easy Bluetooth connection.
MATTHEW GIORIO
Loving it so far.
Windows 11 - All I had to do was pair it to my PC (Bluetooth) and I was up and running. Love the simplistic functional design. It’s overall a great addition to my workspace.
Andrew
Almost perfect..
Very premium and heavy with its sharp yet eligent feel to it oh and the click feel you get from turning the knob with that satisfying noise from the zinc body. Amazing for its price point. Although its almost perfect I would like to see some addons to the second version like push on volume knob to start and stop or mute maybe eventually customize it with software. Also sleep state with the ring light will be good. The volume knob is nice but if feels loose sometimes hope there will be a more sturdy model on the next version. Still a very great purchase. Very Happy!
