$49.99 USD
$49.99 USD
$49.99 USD
Father's Day Save 15%
CODE: FADA15
Color: Gray
CNC All-Metal Zinc Alloy
Remote Volume Adjustment
Infrequent Recharging Needed
Ease of Use
The Volume On-the-Fly
  • VOL20 *1
  • USER MANUALL *1
Based on 28 reviews
68%
(19)
14%
11%
4%
4%
Petar Vrca
Great build quality, but...
... device doesn't work while charging and play/stop button sometimes randomly stops working.
Eric Porlier
Mute is missing, but that’s still a good product
Like the vol20, even though it’s not perfect: it’s missing a Mute Touch button, and even if we can get the volume to go to 0 very fast, it is a miss. Otherwise, I can’t get it to last more than 30 hours on battery/bluetooth. That’s a shame, but that wasn’t important to me from the beginning. Bttons are not easy enough to find, but again, that was not important to me. It does change the volume of my Mac very well, and that’s what I was hoping for.
r
ricky singh
RGB!!!
Very very nice device. I have not experienced an issue with it. Connects to Bluetooth on PC.
The RGB is amazing!!!!
Mark Phieler
Fosi Bluetooth Volume Knob
Great for conference calls and working from home. Well made.
William
Great feeling knob but bluetooth connection is terrible
The knob has a nice feel and weight to it. I actually don't mind the wobble. I would rate this 5 stars but the bluetooth connection is terrible. It constantly disconnects and reconnects. It's sitting 6 inches from my mini pc so it's not a range issue. I have tried it on 3 different pc's and they all exhibit the same behavior. Also windows has no idea what the battery percentage is at, it just seems to give a random number. Hopefully they come out with a gen 2 with either better bluetooth or a 2.4ghz dongle. I would buy it in a heartbeat.
