$49.99 USD
$49.99 USD
$49.99 USD
Color: Gray
CNC All-Metal Zinc Alloy
Remote Volume Adjustment
Infrequent Recharging Needed
Ease of Use
The Volume On-the-Fly
  • VOL20 *1
  • USER MANUALL *1
Based on 26 reviews
73%
(19)
12%
8%
4%
4%
r
ricky singh
RGB!!!
Very very nice device. I have not experienced an issue with it. Connects to Bluetooth on PC.
The RGB is amazing!!!!
Mark Phieler
Fosi Bluetooth Volume Knob
Great for conference calls and working from home. Well made.
William
Great feeling knob but bluetooth connection is terrible
The knob has a nice feel and weight to it. I actually don't mind the wobble. I would rate this 5 stars but the bluetooth connection is terrible. It constantly disconnects and reconnects. It's sitting 6 inches from my mini pc so it's not a range issue. I have tried it on 3 different pc's and they all exhibit the same behavior. Also windows has no idea what the battery percentage is at, it just seems to give a random number. Hopefully they come out with a gen 2 with either better bluetooth or a 2.4ghz dongle. I would buy it in a heartbeat.
Cameron
how does this work? is there a wiring/protocol diagram?
It's unclear to me what devices this works with. The FAQ didn't answer this question. The only pictures show the device on the desktop.
i
ivan
Knob wobble and charging restrictions.
minus 1 star because the knob/dial really does feel loose and tends to wobble as you spin it.
minus 2 more stars because the instructions say not to use fast charging or anything over 5v or risk damaging the device. The whole point of having it charge via USB is to leverage the USB ecosystem re: connectivity and charging options; telling me i have to use the cable you provided or charge via my laptop port is totally bogus.
