$49.99 USD
$49.99 USD
$49.99 USD
Color: Gray
CNC All-Metal Zinc Alloy
Remote Volume Adjustment
Infrequent Recharging Needed
Ease of Use
The Volume On-the-Fly
  • VOL20 *1
  • USER MANUALL *1
Based on 22 reviews
73%
(16)
14%
5%
5%
5%
i
ivan
Knob wobble and charging restrictions.
minus 1 star because the knob/dial really does feel loose and tends to wobble as you spin it.
minus 2 more stars because the instructions say not to use fast charging or anything over 5v or risk damaging the device. The whole point of having it charge via USB is to leverage the USB ecosystem re: connectivity and charging options; telling me i have to use the cable you provided or charge via my laptop port is totally bogus.
Elias
Works great using it on s 2024 mac mini
Michael B
Works perfectly!
Very smooth operation much like a high-end stereo dial. Works perfectly!
Paolo Prodan
The knob you need
Listening music or editing video is a new experience with FOSI Vol20 knob.
Practical and useful… simply perfect.
Nick R.
Works decently most of the time.
Purchased a VOL20 BT knob, shipping was pretty quick from something coming directly from China and it seems to work decently most of the time. Construction is tough as nails and the zinc alloy feels good to the touch. I wish you could set a particular color for the RGB. The options are off, constant green, green for 5 seconds then turns off, or spectrum lighting...so I just leave it off. Better on battery as well I'm sure. Maybe Fosi can add a constant color of your choosing in a firmware update though. The biggest problem is that it often disconnects and then searches for a BT signal. I purchased a TP-Link dongle with a long antenna on it which helped a bit, however it still disconnects and searches for a signal every 30 mins or so for about 10-15 seconds until it reconnects. I'd say it's worth purchasing though just make sure you have a good antenna'd BT dongle. By the way, my VOL20 and BT dongle are only like 5 feet a part so I'm not quite sure why it disconnects and researches for the connection. All in all a good product. I'd recommend it with the addition of the BT dongle with antenna. Perhaps Fosi can make a fix in the firmware with that as well over time. No piece of technology is ever perfect.
