$79.99
+ Free shipping
Bass & Treble Control with Midpoint Positioning
Bluetooth Pairing Cleared
Colour
Power Supply Unit
Quantity
Free shipping
Money-Back Guarantee
Customer support
Fosi Audio SP601 Bookshelf Passive Speakers
$399.99
Fosi Audio Gold-Plated 2 RCA Male to 2 RCA Male Stereo Audio Cable for Home Theater Systems/Amplifier/Preamplifier
$15.99
Fosi Audio Banana Plugs for Speaker Wire, 2 Pairs/4 PCS Gold Plated Speaker Plugs
$9.99
The upgraded version of Fosi Audio BT20A
Input: Bluetooth + RCA; Output: Passive Speakers + Pre-out
Amp chip: TPA3255; MAX Output Power: 300Wx2@4Ω
THD: ≤ 0.005%; SNR: ≥108dB; Frequency Response Range: 20Hz-20kHz(±1.2dB)
Bluetooth 5.0 Connectivity
Allowing you to connect your devices such as mobile phones and tablets from a greater distance, support to SBC/AAC.
Unique Design for Sound Control
Experience the authentic sound without any added effects by adjusting them to their middle points.
Full-range Pre-Out Output
Easily connect to a powered subwoofer, speaker, or another amplifier for versatile audio options.
Texas Instrument TPA3255 Chip
Has a unique smart algorithm that optimizes the output stage for max efficiency and min distortion.
Achieve a Distinct and Exceptional Sound Quality
The two plug-in NE5532 Op-Amps can be replaced by LME49720HA/MUSES02/OPA2134PA Op-Amps, etc.
High Precision and Stability Inductance Values
Low DC resistance and excellent frequency characteristics which improve performance
Front Side
Back Side
Power Variability
Amplifier Comparison Table
BT20A PRO
HT4S
V3
Bluetooth 2.0 CH Amp
Bluetooth 4.1 CH Amp
2.0 CH Amp
300W x 2
30w*4+60W*1
300W x 2
Bluetooth + RCA
BT + 3.5mm AUX + OPT
Passive SPK +Pre-out
Pre-Out+SPK Out
Treble&Bass Control
THD
≤ 0.03%
≥88dB
  • TI TPA3255 Chip Amplifier with 300 Watts x 2 Power Output: Advanced feedback design and high-speed gate driver error correction for efficient and high-quality audio performance, with low idle losses of <2.5W.
  • Upgraded High-Efficiency: A significant upgrade from the BT20A amplifier with replaceable Op-Amps for customized. You can replace the two plug-in NE5532 Op-Amps with MUSES02/OPA2604AP/SS3602 Amps to achieve a unique sound quality. With SNR≥108dB and THD≤0.005%.
  • Enhanced Bluetooth 5.0 Connectivity: The Bluetooth pair can be cleared by pressing and holding the volume control for five seconds. In addition, it has a memory Function for Easy Pairing and Alert Tone.
  • Customizable Sound with a Wide Range of Bass and Treble Controls: The BT20A Pro home audio amplifier offers a unique design for sound control. Enjoy original sound without effects by setting treble and bass effects to the middle point.
  • What you Get: BT20A Pro Power Amplifier x1, Bluetooth Antenna x1, 32V 5A Power Adapter x1, AC Cord x1, User Manual x1, our worry-free 24-month warranty, and friendly customer service.
  • Output Power: 300Wx2 @4Ω
  • Input Mode: Bluetooth + RCA
  • THD: ≤0.005%
  • SNR: ≥108dB
  • Chip Set: TPA3255
  • Bluetooth Antenna x 1
Based on 157 reviews
80%
(126)
12%
(19)
6%
(9)
Goose
Terrible Experience
I made the mistake of ordering directly from FosiAudio.com, and it’s been an extremely frustrating experience. It’s been over three weeks since I placed my order, and I still haven’t received the amplifier. The delivery company Fosi uses to ship from China has failed to deliver to my address twice, despite the fact that I live in a metro area where other carriers have no problem delivering.
When I contacted Fosi Audio to request a refund, they refused to issue one until I receive and return the item—despite the fact that the item is currently in the hands of a delivery service that seems incapable of completing the delivery.
I strongly advise against purchasing directly from FosiAudio.com. The poor logistics and lack of customer support have made this a needlessly stressful and disappointing experience.
Robert Grimes
I ordered it and it came with no power supply.
It came with no power supply. Had to by it separately. I have the BT20A it came with a power supply. Shameful
Joel
Awesome little amp
Sounds great with my bookshelf speakers. Definitely go with the 48v power supply. This thing plays uncomfortably loud without distortion or clipping. Adding a sub really helped. Only improvement I can think of would be an auto power down if no signal for a certain time period.
Manoj Gaonkar
Powerful Little Amplifier
Writing this after just receiving the product, unboxing and playing it via bluetooth, with my Sony bookshelf speakers. Can hardly call this a true review, but had read several other reviews before buying this one. True to my expectations, iit outputs clear sound at good power. I hope to write a detailed review at another point in time after hooking up a CD Player, preamp etc.
Until then no regrets on first looks and trial run.
Samy TAHA
great product
very good sound
