Fosi Audio V3 300W x2 2.0 Channel Hi-Fi Stereo Audio Amplifier with TPA3255 Chip
$109.99
+ Free shipping
Audiophile-Grade Capacitors
Groundbreaking Heat Dissipation
Model
Quantity
Free shipping
Money-Back Guarantee
Customer support
$109.99
Fosi Audio ZA3 Balanced Stereo Amplifier Home Audio
$149.99
Fosi Audio P4 Mini Preamp with 3 RCA Inputs, EQ/Bypass, Treble & Bass Tone Control with Remote Control
$99.99
Born for HiFi Enthusiasts
Max Power Output: 300Wx2@4Ω
SINAD: 88dB | SNR: ≥110dB
THD: ≤0.003% | Noise Floor: 140uV ;Frequency Response: 20Hz-20kHz
TI TPA3255 Integrated
Enabling superior audio quality & ultra-low distortion across the audio band with Class-D efficiency
Swappable Op-Amps
Compatible with 8-pin dual op-amps. Roll them to get your preferred sound signature
Audiophile-Grade Capacitorsn
Built-in quality Japanese NCC, ELNA, and German WIMA capacitors for outstanding performance
Japanese SUMIDA Inductors
Professional audio inductors which have lower impedance and enables support for larger currents
Vents on the top and bottom, and whole-body heatsink design enhance air circulation and cooling
Bookshelf Scene
Home Theater
Desktop Scene
Amplifier Comparison Table
BT20A PRO
HT4S
V3
Bluetooth 2.0 CH Amp
Bluetooth 4.1 CH Amp
2.0 CH Amp
300W x 2
30w*4+60W*1
300W x 2
Bluetooth + RCA
BT + 3.5mm AUX + OPT
Passive SPK +Pre-out
Pre-Out+SPK Out
Treble&Bass Control
THD
≤ 0.03%
≥88dB
  • Compact Yet Powerful: The V3 mini power amplifier combines a minimalist design with exceptional performance. With a power output of up to 600W, it can effortlessly drive 2-8Ω speakers, delivering impressive sound quality. Its compact size makes it suitable for various applications, from bookshelves and desktop setups to home theaters.
  • Audiophile-Grade Components: It features the TPA3255 high-end digital class D amp chip and utilizes premium Japanese NCC, ELNA, and German WIMA capacitors, and Japanese Sumida inductors for exceptional audio quality. With a SINAD rating of up to 88dB, an SNR of up to 110dB, and a low noise floor of only 140uV, it delivers exceptional clarity and low distortion.
  • Innovative Cooling: The V3 stands out with its groundbreaking heat dissipation design. Equipped with vents on the casing's top and bottom, and a whole-body heatsink design, it efficiently dissipates heat, preventing damage to components and ensuring optimal performance.
  • Scalable and Fun: Tailor your sound experience by swapping the stock NE5532 op-amps. V3 is compatible with a variety of 8-pin dual op-amps like Sparkos SS3602, MUSES02, OPA2604, OPA2134PA, OP249, AD827, RM4559, LM4562, LME49720HA, etc.
  • Worry-Free: Enjoy peace of mind with the V3 stereo amplifier. It comes with a 24-month warranty, ensuring reliable performance and customer satisfaction. Note: The "Pre-out" level is NOT controlled by the volume control as the V3 is not an integrated amplifier, so the sound is NOT adjustable when you are connected to the "Pre-out". Note: It doesn't come with the orange knob.
  • Chip Set: TI TPA3255
  • Output Power: 300Wx2 @4Ω
  • Input Mode: RCA
  • SINAD: 88dB
  • THD: 0.003%
  • SNR: ≥110dB
  • V3 Power Amplifier x 1
Based on 163 reviews
90%
(146)
5%
(8)
4%
(6)
Miriam Lambert Lambert
Thank you it works great
Kristian Feichtinger
Absolutely fantastic !
This one is really really a good thing. I woke up my 1992 B&W Matrix 805, after they have been unused for several years, because they sounded very terrible on my Yamaha R-S202D Stereo receiver.. now I found this type of mini amplifier, I've never noticed it before.. the fosi v3 was the best buy in the last years for me. I've never heard my speakers with such a powerful, clear, wide sound stage. Absolutely recommend this one, and better get it with the 48v/5A power supply.
Maxim Skoblinsky
The sound is decent, but the power is hugely exaggerated!
Fosi Audio V3 left a generally positive impression. The sound is fairly clean, with good detail and control in the mids and highs. It was pleasantly surprising that even in its stock configuration (without op-amp upgrades), the unit delivers decent clarity and musicality.
However, the claimed 155W per channel at 6 Ohms with a 48V/5A power supply is highly questionable — in real-world use, the amplifier barely drives my Tannoy Reveal speakers (50W / 6 Ohms). Subjectively, the output feels closer to 30W per channel at an acceptable distortion level. This is especially noticeable when compared to more modest amplifiers like the Yamaha Pianocraft RX-E410, which, despite being rated at only 40W / 6 Ohms, had no trouble powering the same speakers and still had noticeable headroom. In this light, the Fosi V3 falls short even compared to entry-level branded amps.
It may be suitable for low-power or high-sensitivity speakers, but it’s clearly underpowered for more demanding setups...
Overall, it's not a bad amplifier — but for the slightly exaggerated power specs in the description: minus 2 stars.
David Solomon
Good for the price
Sounds like sandpaper on my ears with the stock op-amp. After switching to the SparkoS Labs SS3602 it smoothed out significantly. I could live with it but my 5X the price tube amp sounds better.
Lance
Great Value
The V3 isn’t quite up to the sound quality of the V3 Monos, but for the price it’s an INCREDIBLE value. The V3 is single-handedly responsible for me diving down the budget audiophile rabbit hole… this amp is a gateway drug!
