Fosi Audio V3 300W x2 2.0 Channel Hi-Fi Stereo Audio Amplifier with TPA3255 Chip
$109.99
+ Free shipping
Audiophile-Grade Capacitors
Groundbreaking Heat Dissipation
Model
Quantity
Free shipping
Money-Back Guarantee
Customer support
$109.99
$149.99
Fosi Audio P4 Mini Preamp with 3 RCA Inputs, EQ/Bypass, Treble & Bass Tone Control with Remote Control
$99.99
Born for HiFi Enthusiasts
Max Power Output: 300Wx2@4Ω
SINAD: 88dB | SNR: ≥110dB
THD: ≤0.003% | Noise Floor: 140uV ;Frequency Response: 20Hz-20kHz
TI TPA3255 Integrated
Enabling superior audio quality & ultra-low distortion across the audio band with Class-D efficiency
Swappable Op-Amps
Compatible with 8-pin dual op-amps. Roll them to get your preferred sound signature
Audiophile-Grade Capacitorsn
Built-in quality Japanese NCC, ELNA, and German WIMA capacitors for outstanding performance
Japanese SUMIDA Inductors
Professional audio inductors which have lower impedance and enables support for larger currents
Vents on the top and bottom, and whole-body heatsink design enhance air circulation and cooling
Bookshelf Scene
Home Theater
Desktop Scene
Amplifier Comparison Table
BT20A PRO
HT4S
V3
Bluetooth 2.0 CH Amp
Bluetooth 4.1 CH Amp
2.0 CH Amp
300W x 2
30w*4+60W*1
300W x 2
Bluetooth + RCA
BT + 3.5mm AUX + OPT
Passive SPK +Pre-out
Pre-Out+SPK Out
Treble&Bass Control
THD
≤ 0.03%
≥88dB
  • Compact Yet Powerful: The V3 mini power amplifier combines a minimalist design with exceptional performance. With a power output of up to 600W, it can effortlessly drive 2-8Ω speakers, delivering impressive sound quality. Its compact size makes it suitable for various applications, from bookshelves and desktop setups to home theaters.
  • Audiophile-Grade Components: It features the TPA3255 high-end digital class D amp chip and utilizes premium Japanese NCC, ELNA, and German WIMA capacitors, and Japanese Sumida inductors for exceptional audio quality. With a SINAD rating of up to 88dB, an SNR of up to 110dB, and a low noise floor of only 140uV, it delivers exceptional clarity and low distortion.
  • Innovative Cooling: The V3 stands out with its groundbreaking heat dissipation design. Equipped with vents on the casing's top and bottom, and a whole-body heatsink design, it efficiently dissipates heat, preventing damage to components and ensuring optimal performance.
  • Scalable and Fun: Tailor your sound experience by swapping the stock NE5532 op-amps. V3 is compatible with a variety of 8-pin dual op-amps like Sparkos SS3602, MUSES02, OPA2604, OPA2134PA, OP249, AD827, RM4559, LM4562, LME49720HA, etc.
  • Worry-Free: Enjoy peace of mind with the V3 stereo amplifier. It comes with a 24-month warranty, ensuring reliable performance and customer satisfaction. Note: The "Pre-out" level is NOT controlled by the volume control as the V3 is not an integrated amplifier, so the sound is NOT adjustable when you are connected to the "Pre-out". Note: It doesn't come with the orange knob.
  • Chip Set: TI TPA3255
  • Output Power: 300Wx2 @4Ω
  • Input Mode: RCA
  • SINAD: 88dB
  • THD: 0.003%
  • SNR: ≥110dB
  • V3 Power Amplifier x 1
Based on 152 reviews
91%
(139)
5%
(7)
Guilherme A
incredible value
Sure there are better amplifiers, but on this price range Fosi is a 5 stars product. Fast and smooth delivery, build quality very decent. Highly regarded as one of the best buys for someone looking for a high quality audio setup before jumping into other level of prices.
BOSKO
Fosi V3 AMP
I'm really satisfied with the purchase so far. I like the sound, but also the esthetic and building quality.
Ammit
Perfect little amp
Best amp i ever heard under 200€. 32v 5A power supply not that loud, but with 48v it's perfect.
Paul Forester Jr
Never used
I thought i could get power supply from another store, sorry Fosi, well it failed. After going to multiple stores home audio car audio, answers were all the same. Fosi, for they are the only ones that that can insure that using that power supply will not damage product , or possible your home.So here shortly i will be ordering 2 power supply from them. Once again listen learned a listen.
Kevin Brandewie
Works great!
