Fosi Audio V3 300W x2 2.0 Channel Hi-Fi Stereo Audio Amplifier with TPA3255 Chip
$89.99 USD
$89.99 USD
$89.99 USD
Model:
Born for HiFi Enthusiasts
Max Power Output: 300Wx2@4Ω
SINAD: 88dB | SNR: ≥110dB
THD: ≤0.003% | Noise Floor: 140uV ;Frequency Response: 20Hz-20kHz
TI TPA3255 Integrated
Enabling superior audio quality & ultra-low distortion across the audio band with Class-D efficiency
Swappable Op-Amps
Compatible with 8-pin dual op-amps. Roll them to get your preferred sound signature
Audiophile-Grade Capacitorsn
Built-in quality Japanese NCC, ELNA, and German WIMA capacitors for outstanding performance
Japanese SUMIDA Inductors
Professional audio inductors which have lower impedance and enables support for larger currents
Groundbreaking Heat Dissipation
Vents on the top and bottom, and whole-body heatsink design enhance air circulation and cooling
Bookshelf Scene
Home Theater
Desktop Scene
  • Compact Yet Powerful: The V3 mini power amplifier combines a minimalist design with exceptional performance. With a power output of up to 600W, it can effortlessly drive 2-8Ω speakers, delivering impressive sound quality. Its compact size makes it suitable for various applications, from bookshelves and desktop setups to home theaters.
  • Audiophile-Grade Components: It features the TPA3255 high-end digital class D amp chip and utilizes premium Japanese NCC, ELNA, and German WIMA capacitors, and Japanese Sumida inductors for exceptional audio quality. With a SINAD rating of up to 88dB, an SNR of up to 110dB, and a low noise floor of only 140uV, it delivers exceptional clarity and low distortion.
  • Innovative Cooling: The V3 stands out with its groundbreaking heat dissipation design. Equipped with vents on the casing's top and bottom, and a whole-body heatsink design, it efficiently dissipates heat, preventing damage to components and ensuring optimal performance.
  • Scalable and Fun: Tailor your sound experience by swapping the stock NE5532 op-amps. V3 is compatible with a variety of 8-pin dual op-amps like Sparkos SS3602, MUSES02, OPA2604, OPA2134PA, OP249, AD827, RM4559, LM4562, LME49720HA, etc.
  • Worry-Free: Enjoy peace of mind with the V3 stereo amplifier. It comes with a 24-month warranty, ensuring reliable performance and customer satisfaction. Note: The "Pre-out" level is NOT controlled by the volume control as the V3 is not an integrated amplifier, so the sound is NOT adjustable when you are connected to the "Pre-out". Note: It doesn't come with the orange knob.
  • Chip Set: TI TPA3255
  • Output Power: 300Wx2 @4Ω
  • Input Mode: RCA
  • SINAD: 88dB
  • THD: 0.003%
  • SNR: ≥110dB
  • V3 Power Amplifier x 1
Based on 113 reviews
95%
(107)
4%
(5)
Doug Oxendale
Very good with a flaw
A really big problem was not knowing that I needed a DAC so would work on my PC that is why I had so many returns and finally went to to Ayima and bought a A07 Max and a A2 DAC from them also
James Noud
Perfect!
An inexpensive amp for my small room that does one thing very well. The standard 32v power supply is more than enough in my 9x10 room with Micca RB42 speakers. The volume control rarely needs to hit 11:00 o’clock.
Mick
An amazing piece of kit
I bought the V3 for my study and use it with a Wiim Streamer and a dedicated DAC. As speakers I use B&W 602.
This little amp exceeded my expectations. Sound is warm, full and rich. The detailed presentation lacks just ... nothing. Bass is good, the mids and highs are fine. The sound stage is present. All instruments have their place. I could not ask for more. Much better than the huge Denon AV Receiver, I used in the study before.
5 years ago I would have never bought an amp with only one input. But times are changing. Today i stream 100% of my music from the cloud. I use a Wiim Streamer to stream to this little amp. The times are over where you did have large stacks of hifi sources.
Roger Smith
Great little amp
The V3 300 watt 2-ch amp does exactly what it’s supposed to do. And it’s simple and small and looks terrific.
Customer
Verdaderamente impresionante.
Es el amplificador ideal para espacios reducidos. Su diseño sencillo y pulcro lo hace más atractivo, solo una perilla para encenderlo y manejar el volumen, un led azul indica que está encendido, en diseño dicen que menos es más, en este caso aplica perfecto.
Todos los materiales de gran calidad.
El sonido es un tema aparte, no deja de sorprender la claridad y la definición que se puede obtener, en mi caso lo tengo conectado a unos Beovox S45-2 y los maneja sin ningún problema. Totalmente recomendable.
