$109.99 USD
$109.99 USD
$109.99 USD
Limited Time Save 15%
CODE: LTD15
Model:
Continuation of Co-Creation
Compact Yet Powerful
Advanced Cooling Design
With Minimalist Design
Automatic Signal Sensing
NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
  • Channel : 1.0
  • Input : RCA, XLR, ¼" TRS
  • SNR : ≥123dB
  • Dynamic Range : ≥123dB
  • THD : <0.006%
  • Terminal Impedance : 2-8Ω
  • Standard PSU : 48V/5A
  • V3 MONO Power Amplifier
Based on 102 reviews
76%
(78)
11%
(11)
7%
(7)
5%
(5)
Steven C
Fosi Audio V3 Desktop nearfield
Have a za3 but didn't need a volume knob or a sub out. "Upgraded" to these for my desktop near field 2 channel system. Using them with a Geshelli J2s 4499 with Sparkos 3602 op amps going to a Topping a70pro, then to these mono blocks. I can't hear a difference between them and the za3 using the same op amps, muses02. I am very satisfied with the auto on feature, there is no need for trigger in. They get a lot warmer than the za3, but that's expected with their size. I recommend these for desktop amps if you are tight on space or just don't want to spend a lot for mono blocks, since the next cheapest mono block is twice the price of two of these.
n
neeraj kumar
Fosi v3 Mono is pure audiophile awesomeness
Perhaps one of the best sounding amp out of the box. I have listened to the amp with the stock opamps, driving my Focal 3way tower with ease. The sound stage is fantastic way better than the overpriced Cambridge Audio Azur 851W. I cannot help but to look at that little thing in owe. A beast in small factor. Way to go Fosi. Thanks for making affordable audiophile products. Any future buy fosi will be the place i shall look for. One thing missing is a network streamer supporting all file formats. Hopefully Fosi will listen as always.
Siby Koshy
Great Mono Amp for audiophiles
The performance of the amp is excellent, I have two of them with two separate power supply. This when connected through XLR cable to a balanced DAC gives you impeccable performance. Highly recommended for anyone wanting to try out mono amps, rest assured there is very little compromise with these amps.
Rabbit
2x Fosi V3 mono
The price/performance ratio is great.
For the money, it’s hard to find anything better.
With a good preamp or streamer, it sounds excellent.
I recommend it.
Sam Jones
Good potential
My kids purchased these without my knowledge, or advance research. We didn’t take delivery, as a result.
Nothing up or down to say about personal experience with the items, since we didn’t accept the mailer. Customer service pushback for the return was haha (they “offered the option” of my “gifting them to someone else,” instead of a return). Three stars only because they made return a bit of a hassle.
FYI there are several reviewers online, including several to whom Fosi sent the items for review, who stress tested of these monoblocks and they caught fire. For one reviewer, Fosi replaced the burned tester and the replacement burned, as well.
The reviewers stress tests were more than what my kids would likely do, but I don’t want them to make a mistake and burn the house down. When I brought up these concerns with Fosi, they suggested I put a fan on the monoblocks, while running. Maybe that would help, but do you want that sort of item for your kids? No mention of if an earlier production round issue which they corrected.
Reading up, Fosi seems to be an Innovative company making genuine headway with their products. Might revisit them later when they sort out the bugs.
