$109.99 USD
$109.99 USD
$109.99 USD
Model:
Continuation of Co-Creation
Compact Yet Powerful
Advanced Cooling Design
With Minimalist Design
Automatic Signal Sensing
NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
  • Channel : 1.0
  • Input : RCA, XLR, ¼" TRS
  • SNR : ≥123dB
  • Dynamic Range : ≥123dB
  • THD : <0.006%
  • Terminal Impedance : 2-8Ω
  • Standard PSU : 48V/5A
  • V3 MONO Power Amplifier
Based on 104 reviews
75%
(78)
12%
(12)
7%
(7)
6%
(6)
Fabrizio Maiolini
Eccellente
Ottimi, solo alcune piccole cose; i piedini sono minuscoli, non permettono quindi un raffreddamento ottimale, sostituiti con altri alti 30 mm e il raffreddamento è nettamente migliorato; la sostituzione degli operazioni è sostanzialmente inutile, quantomeno io non ho notato differenze: per il resto prodotto dal rapporto qualità prezzo stellare.
Kevin J Bourassa
Truely High Fidelity Litening
I started early lasy year (2024) with a Fosi V3 stereo amplifier driving a set of Klipsch RP600m speakers and it was very nice. But I have recently upgraded to Fosi V3 Mono Block amps with MUSES02 Op Amps powered by a Fosi 48VDC 10 amp supply thru a Fosi inline power filter and the amps are being signal feed by a Wiim Ultra via its USB output into a Fosi ZD3 DAC then out to the amps via XLR balanced output. The ZD3 has the stock op amps but I have some SX52B descrete op amps that I plan to roll into the ZD3 soon. Overall the system's sound is a true "FRENCH KISS"!!! I have a high end Denon and a upper tier Yamaha integrated amps for comparison and the Fosi's are cleaner with a wider sound stage and very good instrument/artist speration. The bass is very quick, clean and accurate. Oh, sorry but the the Klipsch RP600M's are great but the new monos are now hooked to a new set of Klipsch RP8000F II's towers. Just let me say that I now look forward to getting home from work and just relaxing listening to anything, actully the Beatles right now as I am typing this review. Two enthusiastic thumbs Fosi!!!
Steven C
Fosi Audio V3 Desktop nearfield
Have a za3 but didn't need a volume knob or a sub out. "Upgraded" to these for my desktop near field 2 channel system. Using them with a Geshelli J2s 4499 with Sparkos 3602 op amps going to a Topping a70pro, then to these mono blocks. I can't hear a difference between them and the za3 using the same op amps, muses02. I am very satisfied with the auto on feature, there is no need for trigger in. They get a lot warmer than the za3, but that's expected with their size. I recommend these for desktop amps if you are tight on space or just don't want to spend a lot for mono blocks, since the next cheapest mono block is twice the price of two of these.
n
neeraj kumar
Fosi v3 Mono is pure audiophile awesomeness
Perhaps one of the best sounding amp out of the box. I have listened to the amp with the stock opamps, driving my Focal 3way tower with ease. The sound stage is fantastic way better than the overpriced Cambridge Audio Azur 851W. I cannot help but to look at that little thing in owe. A beast in small factor. Way to go Fosi. Thanks for making affordable audiophile products. Any future buy fosi will be the place i shall look for. One thing missing is a network streamer supporting all file formats. Hopefully Fosi will listen as always.
Siby Koshy
Great Mono Amp for audiophiles
The performance of the amp is excellent, I have two of them with two separate power supply. This when connected through XLR cable to a balanced DAC gives you impeccable performance. Highly recommended for anyone wanting to try out mono amps, rest assured there is very little compromise with these amps.
