$109.99 USD
$109.99 USD
$109.99 USD
Model:
Continuation of Co-Creation
Compact Yet Powerful
Advanced Cooling Design
With Minimalist Design
Automatic Signal Sensing
NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
  • Channel : 1.0
  • Input : RCA, XLR, ¼" TRS
  • SNR : ≥123dB
  • Dynamic Range : ≥123dB
  • THD : <0.006%
  • Terminal Impedance : 2-8Ω
  • Standard PSU : 48V/5A
  • V3 MONO Power Amplifier
Based on 103 reviews
76%
(78)
11%
(11)
7%
(7)
6%
(6)
Kevin J Bourassa
Truely High Fidelity Litening
I started early lasy year (2024) with a Fosi V3 stereo amplifier driving a set of Klipsch RP600m speakers and it was very nice. But I have recently upgraded to Fosi V3 Mono Block amps with MUSES02 Op Amps powered by a Fosi 48VDC 10 amp supply thru a Fosi inline power filter and the amps are being signal feed by a Wiim Ultra via its USB output into a Fosi ZD3 DAC then out to the amps via XLR balanced output. The ZD3 has the stock op amps but I have some SX52B descrete op amps that I plan to roll into the ZD3 soon. Overall the system's sound is a true "FRENCH KISS"!!! I have a high end Denon and a upper tier Yamaha integrated amps for comparison and the Fosi's are cleaner with a wider sound stage and very good instrument/artist speration. The bass is very quick, clean and accurate. Oh, sorry but the the Klipsch RP600M's are great but the new monos are now hooked to a new set of Klipsch RP8000F II's towers. Just let me say that I now look forward to getting home from work and just relaxing listening to anything, actully the Beatles right now as I am typing this review. Two enthusiastic thumbs Fosi!!!
Steven C
Fosi Audio V3 Desktop nearfield
Have a za3 but didn't need a volume knob or a sub out. "Upgraded" to these for my desktop near field 2 channel system. Using them with a Geshelli J2s 4499 with Sparkos 3602 op amps going to a Topping a70pro, then to these mono blocks. I can't hear a difference between them and the za3 using the same op amps, muses02. I am very satisfied with the auto on feature, there is no need for trigger in. They get a lot warmer than the za3, but that's expected with their size. I recommend these for desktop amps if you are tight on space or just don't want to spend a lot for mono blocks, since the next cheapest mono block is twice the price of two of these.
n
neeraj kumar
Fosi v3 Mono is pure audiophile awesomeness
Perhaps one of the best sounding amp out of the box. I have listened to the amp with the stock opamps, driving my Focal 3way tower with ease. The sound stage is fantastic way better than the overpriced Cambridge Audio Azur 851W. I cannot help but to look at that little thing in owe. A beast in small factor. Way to go Fosi. Thanks for making affordable audiophile products. Any future buy fosi will be the place i shall look for. One thing missing is a network streamer supporting all file formats. Hopefully Fosi will listen as always.
Siby Koshy
Great Mono Amp for audiophiles
The performance of the amp is excellent, I have two of them with two separate power supply. This when connected through XLR cable to a balanced DAC gives you impeccable performance. Highly recommended for anyone wanting to try out mono amps, rest assured there is very little compromise with these amps.
Rabbit
2x Fosi V3 mono
The price/performance ratio is great.
For the money, it’s hard to find anything better.
With a good preamp or streamer, it sounds excellent.
I recommend it.
