$109.99 USD
$109.99 USD
$109.99 USD
Model:
Continuation of Co-Creation
Compact Yet Powerful
Advanced Cooling Design
With Minimalist Design
Automatic Signal Sensing
NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
  • Channel : 1.0
  • Input : RCA, XLR, ¼" TRS
  • SNR : ≥123dB
  • Dynamic Range : ≥123dB
  • THD : <0.006%
  • Terminal Impedance : 2-8Ω
  • Standard PSU : 48V/5A
  • V3 MONO Power Amplifier
Based on 106 reviews
74%
(78)
13%
(14)
7%
(7)
6%
(6)
Terje HAUG
All OK
Everything worked out as planned. The ordering (direct from Fosi) was easy, same was the payment on the ordering page.
The dilevery took about 10 days to Norway - so very good.
And the sound is very satisfying and as I aspected. I use them as front apmlifiers in a home theatre.
a
a copsey
Only one flaw...
Only one flaw that I can find that is - that turn on click. That is ugly.
Audio Science Review rated the Fosi the same as NAD's C298 power amp. I happen to have the NAD and I can't argue with the ASR review, and that is without taking the price into account.
Fix the turn-on click, and, better, add a trigger input and I might just give it 5 stars :)
Fabrizio Maiolini
Eccellente
Ottimi, solo alcune piccole cose; i piedini sono minuscoli, non permettono quindi un raffreddamento ottimale, sostituiti con altri alti 30 mm e il raffreddamento è nettamente migliorato; la sostituzione degli operazioni è sostanzialmente inutile, quantomeno io non ho notato differenze: per il resto prodotto dal rapporto qualità prezzo stellare.
Kevin J Bourassa
Truely High Fidelity Litening
I started early lasy year (2024) with a Fosi V3 stereo amplifier driving a set of Klipsch RP600m speakers and it was very nice. But I have recently upgraded to Fosi V3 Mono Block amps with MUSES02 Op Amps powered by a Fosi 48VDC 10 amp supply thru a Fosi inline power filter and the amps are being signal feed by a Wiim Ultra via its USB output into a Fosi ZD3 DAC then out to the amps via XLR balanced output. The ZD3 has the stock op amps but I have some SX52B descrete op amps that I plan to roll into the ZD3 soon. Overall the system's sound is a true "FRENCH KISS"!!! I have a high end Denon and a upper tier Yamaha integrated amps for comparison and the Fosi's are cleaner with a wider sound stage and very good instrument/artist speration. The bass is very quick, clean and accurate. Oh, sorry but the the Klipsch RP600M's are great but the new monos are now hooked to a new set of Klipsch RP8000F II's towers. Just let me say that I now look forward to getting home from work and just relaxing listening to anything, actully the Beatles right now as I am typing this review. Two enthusiastic thumbs Fosi!!!
Steven C
Fosi Audio V3 Desktop nearfield
Have a za3 but didn't need a volume knob or a sub out. "Upgraded" to these for my desktop near field 2 channel system. Using them with a Geshelli J2s 4499 with Sparkos 3602 op amps going to a Topping a70pro, then to these mono blocks. I can't hear a difference between them and the za3 using the same op amps, muses02. I am very satisfied with the auto on feature, there is no need for trigger in. They get a lot warmer than the za3, but that's expected with their size. I recommend these for desktop amps if you are tight on space or just don't want to spend a lot for mono blocks, since the next cheapest mono block is twice the price of two of these.
