$109.99 USD
$109.99 USD
$109.99 USD
Model:
Continuation of Co-Creation
Compact Yet Powerful
Advanced Cooling Design
With Minimalist Design
Automatic Signal Sensing
NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
  • Channel : 1.0
  • Input : RCA, XLR, ¼" TRS
  • SNR : ≥123dB
  • Dynamic Range : ≥123dB
  • THD : <0.006%
  • Terminal Impedance : 2-8Ω
  • Standard PSU : 48V/5A
  • V3 MONO Power Amplifier
Q: The V3 Mono has three op-amps. What does each one do? And if l want to get a better sound, which one should l change?
A: The three op-amps in the V3 Mono serve distinct functions: Position 1 converts the RCA unbalanced signal to a balanced signal, while positions 2 and 3 adjust the tone. lf you're considering replacing an op-amp, it's recommended to start with the one in position 2. Replacing both the op-amps in positions 2 and 3 will have a more noticeable effect. Users can try swapping different op-amps to experience changes in sound quality.
Q: For the V3 Mono do I need any specific type of op-amp?
A: It supports DIP8 dual op-amps. We highly recommend the op-amp available through the following link: https://fosiaudio.com/products/op-amp-chip-muses02-opa2604ap-opa2134pa?_pos=20&_sid=71ca24042&_ss=r
Q: The V3 MONO's power LED does not work but it outputs sound.
A: Check if the LED is out of position after swapping the op-amp. Open the unit and align the LED correctly.
Based on 117 reviews
74%
(86)
14%
(16)
7%
(8)
5%
(6)
Donnie L
V3 monos
m
miha
Decent product
Nice if separte PSUs
S R
Powerful
Powerful compared to its size.
Naman
Best design
Superb design, so compact love it.
Blaine G
Incredible performance value
The V3 monoblocks are as good as all the reviewers claim. They pack a mighty punch for their size. I highly recommend going for the biggest power supply (48V, 10A), you will not be disappointed. I'm looking forward to testing them on larger speakers. Very well done Fosi Audio!
