$109.99 USD
$109.99 USD
$109.99 USD
Model:
Continuation of Co-Creation
Compact Yet Powerful
Advanced Cooling Design
With Minimalist Design
Automatic Signal Sensing
NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
  • Channel : 1.0
  • Input : RCA, XLR, ¼" TRS
  • SNR : ≥123dB
  • Dynamic Range : ≥123dB
  • THD : <0.006%
  • Terminal Impedance : 2-8Ω
  • Standard PSU : 48V/5A
  • V3 MONO Power Amplifier
Q: The V3 Mono has three op-amps. What does each one do? And if l want to get a better sound, which one should l change?
A: The three op-amps in the V3 Mono serve distinct functions: Position 1 converts the RCA unbalanced signal to a balanced signal, while positions 2 and 3 adjust the tone. lf you're considering replacing an op-amp, it's recommended to start with the one in position 2. Replacing both the op-amps in positions 2 and 3 will have a more noticeable effect. Users can try swapping different op-amps to experience changes in sound quality.
Q: For the V3 Mono do I need any specific type of op-amp?
A: It supports DIP8 dual op-amps. We highly recommend the op-amp available through the following link: https://fosiaudio.com/products/op-amp-chip-muses02-opa2604ap-opa2134pa?_pos=20&_sid=71ca24042&_ss=r
Q: The V3 MONO's power LED does not work but it outputs sound.
A: Check if the LED is out of position after swapping the op-amp. Open the unit and align the LED correctly.
Based on 115 reviews
74%
(85)
14%
(16)
6%
(7)
5%
(6)
S R
Powerful
Powerful compared to its size.
Naman
Best design
Superb design, so compact love it.
Blaine G
Incredible performance value
The V3 monoblocks are as good as all the reviewers claim. They pack a mighty punch for their size. I highly recommend going for the biggest power supply (48V, 10A), you will not be disappointed. I'm looking forward to testing them on larger speakers. Very well done Fosi Audio!
William
Best bang for the buck amps I have found
Was looking for a desktop setup to replace my Schiit Vidar monoblocks. These sound every bit as good but are much smaller and a fraction of the price. The TPA3255 is an amazing chip and Fosi have built an incredible amp around it, at a price that is unbelievably good. I'm using them to power my LS50 Metas and they have plenty of power to push them to uncomfortably loud levels. I upgraded the opamps to Sparkos SS3602, which was definitely an improvement, but it nearly doubles the cost of the system, so I'm not sure I would recommend it. The amps do get hot because they use the chassis as a heat sink. It was a little concerning at first but I've been running them for almost a year with no issues.
Phil
Little footprint, Big kick!
I love these little guys. They’ve easily powered every speaker I’ve thrown at them including B&Ws.
