$109.99 USD
$109.99 USD
$109.99 USD
Model:
Continuation of Co-Creation
Compact Yet Powerful
Advanced Cooling Design
With Minimalist Design
Automatic Signal Sensing
NICHICON Caps, Japanese
WIMA Caps, German
Sumida Inductor, Japanese
ELNA Caps, Japan
  • Channel : 1.0
  • Input : RCA, XLR, ¼" TRS
  • SNR : ≥123dB
  • Dynamic Range : ≥123dB
  • THD : <0.006%
  • Terminal Impedance : 2-8Ω
  • Standard PSU : 48V/5A
  • V3 MONO Power Amplifier
Q: The V3 Mono has three op-amps. What does each one do? And if l want to get a better sound, which one should l change?
A: The three op-amps in the V3 Mono serve distinct functions: Position 1 converts the RCA unbalanced signal to a balanced signal, while positions 2 and 3 adjust the tone. lf you're considering replacing an op-amp, it's recommended to start with the one in position 2. Replacing both the op-amps in positions 2 and 3 will have a more noticeable effect. Users can try swapping different op-amps to experience changes in sound quality.
Q: For the V3 Mono do I need any specific type of op-amp?
A: It supports DIP8 dual op-amps. We highly recommend the op-amp available through the following link: https://fosiaudio.com/products/op-amp-chip-muses02-opa2604ap-opa2134pa?_pos=20&_sid=71ca24042&_ss=r
Q: The V3 MONO's power LED does not work but it outputs sound.
A: Check if the LED is out of position after swapping the op-amp. Open the unit and align the LED correctly.
Based on 109 reviews
73%
(80)
14%
(15)
6%
(7)
6%
(6)
Mladen Cvijanovic
Amazing Little D-Class Mono Amp(s)
No words to simply explain these (I got two of course). Brings clarity to each song I played. Being D Class, does not give that "harsh" sound but more on a softer, warmer side. I paired it with MC331 amp (used as pre-amp) in this case for Bass, Treble and Volume and wow how amazed I got. Sounded almost as my Sansui AU-217 and I will be honest, out of all my amps, Sansui is far the best. However, it was time to try Fosi and they did not disappoint. Lot of power from one little box and (must say) chunky external power supply. I ordered pair with 48V 5A PS for each as I read that ppl had some noise with one 48V 10A PS. We all know PS per channel is better. I also think that PS is GaN which actually makes it smaller than it would be if it was regular silicone, so that's a plus too.
I think, I am slowly switching towards Fosi even I like my old A and AB amps. But size, looks, quality, simplicity and customer orientation of Fosi, right now, cannot be beaten.
I have one suggestion to Fosi: please do not ship with FedEx in US - terrible experience in last few years, for me at least.
Mark Capener
The mono amp is a bargain with the choice of switching op amp and the 48 volt gan per supply and ...
Fantastic as good as my 10k class d amps
Dylan Myers
Would recommend, but positioning may be troublesome
Right out of the box, just holding them in my hand I could tell they were well put together little beasts. The switches in front feel really good, and the connectors in the back seemed sturdy. I was a little bit caught off guard by how small the binding posts were and I had a little bit of trouble sticking the bare wire in, and the rotation of the holes for the wire was not the same on both posts (maybe they can be rotated back, but I didn’t try that). I got the package with 1 power supply which splits into two cords, and because the amps are quite light, and the weight and stiffness of the power cords and cord splitter thing is enough to make positioning them a little bit difficult, but once they’re set they’re set. The cord from the wall to the power supply is also very short which makes positioning more strict. But I got them set up and plugged in and they’re working perfectly! They’re powering a pair of Paradigm Monitor SE 6000f speakers and compared to my Denon avr 570 that I had them powered with previously, the bass is so much more powerful and detailed. I don’t want to talk too much on the sound because I haven’t much experience to compare it to since they’re only my second amp. Something I do notice and as have other reviewers online, they can’t get quite warm to the touch when driving at louder volumes. They have never gotten to the point that they are too hot to touch, and I haven’t noticed any degradation to the sound when they heat up, so they must be engineered with the heat in mind. I am very satisfied with these monoblocks and would absolutely recommend them to someone on a lower budget looking for some kick in their system.
Terje HAUG
All OK
Everything worked out as planned. The ordering (direct from Fosi) was easy, same was the payment on the ordering page.
The dilevery took about 10 days to Norway - so very good.
And the sound is very satisfying and as I aspected. I use them as front apmlifiers in a home theatre.
a
a copsey
Only one flaw...
Only one flaw that I can find that is - that turn on click. That is ugly.
Audio Science Review rated the Fosi the same as NAD's C298 power amp. I happen to have the NAD and I can't argue with the ASR review, and that is without taking the price into account.
Fix the turn-on click, and, better, add a trigger input and I might just give it 5 stars :)
