$149.99 USD
$149.99 USD
$149.99 USD
Model:
Shipping to:
PBTL Mono Mode Support
Home Audio System
XLR Input
Swappable Op-Amps
12V Trigger Sync Interface
Logarithmic Potentiometer
  • Output Power:
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
  • ZA3 Power Amplifier x 1
Based on 247 reviews
88%
(217)
9%
(22)
John Z
Brought My Speakers to Life!
Just bought this amp from my friend's recommendations and I am blown away! It had brought a whole new meaning to my speakers and basically came back as a 2nd life! Amazing amp!
Ed
Good Power!
Amazing amp, been powering my desktop 2.1 setup on the daily. Wished I had gotten this sooner!
Gary B
There's no catch!
I've been using a pair of these almost daily for about 2 months. I use them in mono mode, unbalanced with the gains around 80%. My speakers are 4-ohm dynaudio Audience 60s or the partsexpress solstice kit.
I was hesitant to be critical because of the low price point and previous dissatisfaction with higher priced amplifiers. However, there isn't much to lose if they turned out to be sub par. They just simply are not sub par. They are stout performers!
I started off with the 48v/5A power supplies, and got the itch to move to the 10A power supplies and the $20 power filters. I have been using those power supplies for about three weeks. There is a noticeable increase in performance and I would consider my overall satisfaction with the amplifiers increased about 10%.
I run them for 3-4 hours at above 50% output and they don't get hot. They can drive power hungry dynaudio towers surprisingly well. They are an ideal power match with the solstice tower speakers.
I finally figured out the 12v trigger situation. I use my WIIM streamer with trigger out to turn them on. Otherwise, turning both amps on and off by holding down the button is unnecessary manual labor.
Absolutely worth the money. A great place to start or stay in hifi amplification.
Jeroen Beukers
Fantastic little amp!
I purchased 2 of them to run them bridged mono into the ZD3 DAC, I am blown away at the power (Using the 48V power supplies) and also using the balanced connections makes a big difference in separation, clean sound, higher output ginal too from the DAC to the amps. I am using these on my older first gen ELAC Debut 6 and Very Very happy with the combo. Keep it up FOSI! :)
Roman Hercigonja
Fosi Audio ZA3
I'm quite satisfied with this amp. Delivering lot of power, with a reasonably clean sound. I had a lot of fun playing with op-amps also. The combination of ZD3-ZA3 (my setup) is a perfect match. As I wrote for ZD3, this is easily recommendable product.
