$149.99 USD
$149.99 USD
$149.99 USD
Model:
Shipping to:
PBTL Mono Mode Support
Home Audio System
XLR Input
Swappable Op-Amps
12V Trigger Sync Interface
Logarithmic Potentiometer
  • Output Power:
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
  • ZA3 Power Amplifier x 1
Based on 242 reviews
88%
(212)
9%
(22)
Michał Koper
ZA3 as monoblocks
My set consists of ZD3 and 2xZA3 as monoblocks powering Dali opticon6. PC with audirvana as sound source. Overally its jaw-dropping. Litterally I dont watch tv, stopped gaming. I just listen music every spare minute. Its amazing no matter how loud you go. First few days I was using one za3 as stereo amp, later I added second za3. I can tell great deal of difference when they work as monoblocks vs stereo, so better dont buy just one. For 20m3 salon in this config 36v power supply is enough.
Larry Mapes
Where's my stuff?
I haven't received my order yet. Whats up?
Martijn
Wonderful little power amp
I bought this amp after reading / watching all the positive reviews. To complete my new desk setup, I was looking for a small but powerful and "clean" amp. The ZA3 delivered! Apart from great sound and for me more then enough lower (no need for the dual mono block setup yet), the amp looks very cool to. As I'm from the Netherlands, I love the orange power / volume button obviously. If you are looking for an affordable and powerful but small amp, look no further. You can't go wrong with this one.
Francois Smith
ZA3 for XLR sound quality...
This is now my second ZA3...
It is running with the ZD3s input and I love that warm precise sound that it supplies to my old Infinity Beta 50 speakers.
Can enjoy it for hours.
Markus Winterleitner
Top notch!
Top notch!
