$149.99 USD
$149.99 USD
$149.99 USD
Model:
Shipping to:
PBTL Mono Mode Support
Home Audio System
XLR Input
Swappable Op-Amps
12V Trigger Sync Interface
Logarithmic Potentiometer
  • Output Power:
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
  • ZA3 Power Amplifier x 1
Based on 238 reviews
88%
(209)
9%
(22)
Markus Winterleitner
Top notch!
Top notch!
Roy Ledwell
Very Impressive!
I bought a bundle so I could use these in mono mode. I have not switched them from stereo mode yet. I am impressed with the output. I have a WiiM Ultra ran to both amps which are pushing two sets of speakers. One set is a pair of Definitive Technologies BP-30’s. They can handle 500 watts per channel. Even in stereo mode with eight ohms these things sound incredible. Love these little amps!!!
Aljosa Krzelj
Happy !
Great little amp
Al Rourke
No power supply
Unfortunately I have not been able to try the ZA3 as it did not come with the power supply.
I did send a email regarding this problem but but have not received a response as of yet. Very frustrating!!
Robert Nüsse
Great Amp
Really improved the sound if my system changing from Class A to Class D amplification. I perceive so much more detail in the sound. The power in stereo with 48V 5 A power supply is plenty, however given the great offer of buying 2 at a 15% discount was so compelling that I ended up getting 2 x ZA3 and purchased 2 x 48 V 10 A power supplies. Now, I know that I am getting the max power out of these 2 running in mono. I really like the quality of the units, very nicely engineered and the styling is also realy nice. What would be nice for future improvements would be a mono switch to circumvene the volume dial in mono mode, when a pre-amp is used to regulate the volume. Also a small LCD indicating the volume level would be a nice feature.
