$149.99 USD
$149.99 USD
$149.99 USD
Model:
Shipping to:
PBTL Mono Mode Support
Home Audio System
XLR Input
Swappable Op-Amps
12V Trigger Sync Interface
Logarithmic Potentiometer
  • Output Power:
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
  • ZA3 Power Amplifier x 1
Based on 235 reviews
88%
(206)
9%
(22)
Al Rourke
No power supply
Unfortunately I have not been able to try the ZA3 as it did not come with the power supply.
I did send a email regarding this problem but but have not received a response as of yet. Very frustrating!!
Robert Nüsse
Great Amp
Really improved the sound if my system changing from Class A to Class D amplification. I perceive so much more detail in the sound. The power in stereo with 48V 5 A power supply is plenty, however given the great offer of buying 2 at a 15% discount was so compelling that I ended up getting 2 x ZA3 and purchased 2 x 48 V 10 A power supplies. Now, I know that I am getting the max power out of these 2 running in mono. I really like the quality of the units, very nicely engineered and the styling is also realy nice. What would be nice for future improvements would be a mono switch to circumvene the volume dial in mono mode, when a pre-amp is used to regulate the volume. Also a small LCD indicating the volume level would be a nice feature.
Magnus Persson
Andreas Ehmann
Clear Sound
I have 4 of these nice amplifiers in mono and with bi-wiring my speakers.
I am absolutely impressed of the clearness and the powerful Sound.
Jean-Pierre Landert
Hervorragend
Begeistert über die Klangliche Leistung vom Gerät, habe ich spontan ein zweites Gerät gekauft und betreibe jetzt diese zwei Geräte als Mono-Endstufen. Mit dem Ersatz der OP-Amps (Muse02) konnte ich eine feine klangliche Steigerung erreichen.
