$149.99 USD
$149.99 USD
$149.99 USD
Model:
Shipping to:
PBTL Mono Mode Support
Home Audio System
XLR Input
Swappable Op-Amps
12V Trigger Sync Interface
Logarithmic Potentiometer
  • Output Power:
  • SINAD: 89dB
  • THD: <0.006%
  • SNR: ≥106dB
  • Dynamic Range: ≥106dB
  • ZA3 Power Amplifier x 1
Based on 233 reviews
88%
(205)
9%
(22)
Magnus Persson
Andreas Ehmann
Clear Sound
I have 4 of these nice amplifiers in mono and with bi-wiring my speakers.
I am absolutely impressed of the clearness and the powerful Sound.
Jean-Pierre Landert
Hervorragend
Begeistert über die Klangliche Leistung vom Gerät, habe ich spontan ein zweites Gerät gekauft und betreibe jetzt diese zwei Geräte als Mono-Endstufen. Mit dem Ersatz der OP-Amps (Muse02) konnte ich eine feine klangliche Steigerung erreichen.
Stretoo
Used as Mono Amps
I bought two ZA3 to complement my ZD3. Unfortunately, the left XLR connection of the ZD3 burned when power was put on. No explanation for that. Anyway great after sale service from Fosi support team who replaced the poor ZD3. Since then everything is fine and I can enjoy the very good ZA3s sound delivered through my two trusty B&W DM640. I'm now testing these two amps with the Fosi P4 preamp for a great result. All the set is equipped with ORACLEII02 OP Amps; I just miss the trigger on the P4 which could be a nice thing to add to this very fine preamp. I would love Fosi to provide us with a tube preamp to drive the ZA3 on the same basis of the P4 but with XLR outputs, a trigger out and an additional RCA/RIAA input for a turntable (it's only a matter of integrating the Fosi BOX5 in it). For the fun I switched on my two ZA3 and the ZD3 to my tube preamp McIntosh C22, what a dream sound! So it would be nice to have a nice Fosi tube preamp to perform the same result.
Top Amp
Ich habe den Amp gekauft da mein Class A Verstärker sehr viel Strom nimmt und ich zum umschalten etwas Stromsparendes gesucht habe! Was soll ich sagen im direkten Vergleich fehlt kaum etwas, zudem braucht der Claas A 20 Minuten um warm zu werden! Bin absolut fasziniert und habe schon einen 2ten gekauft (der hat zwar ein anderes Netzteil!? Beide 48V5A), tut aber auch hervorragend! Klare Kaufempfehlung!!!
